61 - 80 of 90 Posts
Rough country lifts. I’ve got my self another WJ. 04 limited 4.7. I’m looking at lifting this one. There many kits out there. I noticed that Rough Country 4.0 inch lift use a lower control arm relocation bracket. No one else does. Anyone use there kit?
I've updated and replaced quite a few things since my last post in this thread:
Looks fantastic! I'm hot on your heels with the same ideas.
Anything you would change if you did it again?
Is there any reason I shouldn't skip the benchmark and go straight to the long arm kit?
Thanks!
Finally pretty much got the lift done, drove it around about 20 miles and it feels pretty good, need to get the wheel centered up but that's for another thread.
IRO foundation series 3'' coil spring lift
IRO adjustable track bar
Bilstein 5100 series shocks
Moog trail boss HD steering stabilizer
New coil spring isolators front/rear
New front stock sway bar links
Addco rear sway bar
No wheel spacers
265/7517 tires, No rubbing yet but only 20 miles in.
Any rubbing issues with this set up? Was thinking about the same tires for my WJ
yes do you have any rubbing? I was looking at the same tire but in 265/70/16
Sorry for the incredibly late reply! Have since sold that Jeep. Rubbing only at full lock with the steering, I'm sure offroad it would rub in some other locations. Picked up another WJ and planning the same setup. Was very pleased with the ride height and ground clearance, those DT8000 shocks sucked and I would absolutely suggest the Bilsteins (haven't used them yet myself). I purchased through Kolak.
Lift: 6" RockKrawler long arm
Wheels: 15" pacer soft 8's
Tires: 33x12x15 Duratracs
Additional Information:
To much to list
Has anyone on this page used CORE 4x4 Adjustable Control Arms? Thoughts and are they worth the money? Bushings are worn on the stock arms and I think they are about to go...
3.5" of lift, 32" BFG KM's, quick disconnects, Doetsch Tech Shocks
Yes I have used them on a TJ Wrangler and an XJ Cherokee. I just ordered rears for my WJ on Monday. I've never had an issue with them.
Iro critical path long arms
Iro 4 inch springs
Jks adjustable trac bar
Bilstein front 24-185943 for tj with 5.5 lift (they are two inches longer then the ones meant for a wj with 4 inches of lift)
265/75R16
now i have her on 285/75r16s mile star patagonias
i have yet to do any more trimming or even go flex it out fully but i know its going to rub
My chart says 31.4 inches What is the limit 30.0? 245 65 17 is 29.5 At that I guess the factory size is the largest you can go without lift. THe question was because I could have gotten a great deal on 4 245 75 17 tires.
my Parts rig 04 WJ I slapped a set of 265/75r16 off the JK on it they rub quite a bit, so without trimming, and even removing the foglights doubt the 245/17 will work...
Reactions: #1EasyXjer
Before and after: I inherited this 1999 WJ from my grandfather w/ 100,000 miles on it. I got my love of Jeep from him so decided to spend some extra money getting this in good running shape as a second vehicle. Hope it lasts me another 100,000 miles.
Specs to-date:
- Remanufactured 4.7 engine, running like a top
- 2-inch leveling kit by Daystar (KJ09113BK)
- ProComp ES9000 shocks
I took the gently used tires off a 2017 WJ2 Trailhawk I just bought and put them on 18 inch wheels from a 2007 JK. Tire is Wrangler All-Terrain Adv w/ Kevlar, 265/60/18
This thing rides great. Very comfortable. No trimming, but that'll probably change when I get it out on a trail cause it's pretty close as is.
Attaching photo ...
Specs to-date:
Unsure why photo didn't post:
2002 WJ Laredo
4.7L, 242
2.5" front, 2" rear BB
Upcountry rear coils
Addco rear sway bar with Energy bushings
Skyjacker Shocks
DIY a-arm spacer
DIY roof rack with awning and highlift mount
LED light bar
Factory tow hooks, hitch and t-case skid
245/75/16 Duratracs on painted JK steelies
61 - 80 of 90 Posts
