Be sure to check it running in neutral.
It is commonly stated that trans fluid needs to be checked in N, rather than P. However I can confirm that in at least the 2004 owner's manual, it states to check both the 42RE and 545RFE in P.What am I looking for in neutral?
As a veteran transmission rebuilder…that is a misprint.It is commonly stated that trans fluid needs to be checked in N, rather than P. However I can confirm that in at least the 2004 owner's manual, it states to check both the 42RE and 545RFE in P.
View attachment 4173037 View attachment 4173038 View attachment 4173039
I by no means are saying you are wrong, but I find that very hard to believe. That would mean literally 100's of thousands of 4.0 Jeeps are running 1.5qts low. Seems to me, at very least, there would be a TSB stating such a damaging misprint. And how is park any different from just neutral with the parking pawl engaged?that is a misprint.
Well for one, there is more of a difference than just the park pawl being engaged.I by no means are saying you are wrong, but I find that very hard to believe. That would mean literally 100's of thousands of 4.0 Jeeps are running 1.5qts low. Seems to me, at very least, there would be a TSB stating such a damaging misprint. And how is park any different from just neutral with the parking pawl engaged?
Not recommended.How about a little over filled is that ok?
04 Jeep Grand Cherokee SM for 42RE Transmission (4.0L engine) says:I do wish it was clearer as to how to check trans fluid level
