Especially for the four or five of us on here with CRD models! I have noticed that my WJ is slow to start when its below freezing so I tested the glowplugs in situ and three of the four I could reach failed the test....so that explains that then!
Five new Falcon glow plugs bought for £27 inc delivery from eBay arrived at my door a couple of days ago and here is how I fitted then today.
In a lot of cars this would be no more difficult than changing a set of plugs....but not on this one. firstly the fuel rail and its fuel lines and wiring are in the way and secondly, since this engine has been stuffed into a vehicle it was never designed for, access to the rear most (cyls 4 and 5) is limited to say the least. So here goes. I apologise for poor photos and the fact that I forgot to take some at all!
Before you start the engine MUST be up to full operating temp (about 90c)...if not there is a very real chance that the old glow plugs could snap off in the head...meaning head off....expensive. They only take about 20nm to fit and cant take much more than that on removal without shearing so be careful.
Firstly remove the engine cover...pull firmly upwards and off it comes.
This is what you will find underneath.
Remove bracket that hold cover on and locates dip stick tube....this will enable removal of fuel rail fixing bolt.
Remove fuel system bleed valve so fuel rail can be lifted out.
Remove fuel rail pressure sensor.
Remove plug from fuel pressure regulator at far end of rail. Tight but possible with normal size hands! Upper middle of this picture.
Remove main rail fuel supply (links rail to high pressure pump). 14mm spanner (wrench in US!).
Remove all five injector feeds from rail. No need to disconnect them from the injectors but doing so from cyls four and five will give you more room when removing their glow plugs. 14mm
Remove the three bolts that secure fuel rail to head. This is the rear one....tight to access due to fuel return pipe running across it but not impossible. You could remove this pipe from fuel filter to gain more space. I didn't.
Pull rail as far to left as possible to clear space to access glow plugs. There is no need to unbolt 'excess pressure return valve' from end off rail....just make sure you don't over stretch the pipes going to and from it.
Remove glow plugs caps....a pair of needle nosed pliers was my weapon of choice....not much space around the plugs.
Remove all glow plugs slowly and carefully to avoid snapping. Should take no more than light hand pressure on a 3/8 drive socket with a deep reach 10mm socket to get them moving....if it does not budge either leave that one or apply some localised heat if you can. I though number 5 would be the most difficult due to access but it came out easily albeit with a bit of skin loss and only a small arc of movement on the ratchet. Number four was a pain due to the plastic shielding that protects the injector wiring and the engine hoist mount fitted nearby getting in the way. But a bit of patience and they were all out. Hooray!
