Hello! I'm in the process of an LS swap. I started with the stock 4.0L 42RE auto and have installed a 2005 5.3L / 4l60E using many parts from Novak Industries for the swap. I intend to keep the Jeep wiring harness to retain factory gauges/controls along with the re-worked (by Novak) GM harness to run the LS. I pulled the Jeep harness out and removed from it the following circuits to clean it up:
1) O2 sensors
2) Coils
3) Injectors
4) Transmission controls
I have the new motor / tranny (adapted to the original np241 t-case) installed now. and I have both the jeep and GM harness re-installed and connected. I have the battery grounded to the frame, frame to engine, engine to body at original firewall location as well as the firewall to hood factory grounds and have validated continuity between them all. There is also a small ground coming from the cabin through the firewall at the passenger side under the battery tray I have grounded to the frame.
Problem is though, when I connected the battery and turned on the ignition, I have NO POWER inside the Jeep. Everything worked properly before I removed the engine/harness. I am leaning towards a missing ground to the PCM, but I'm not sure how the PCM is grounded / powered?
Anyone who might be able to help nudge me in the right direction to troubleshoot this?
Thanks!
-Todd
1) O2 sensors
2) Coils
3) Injectors
Thanks!
-Todd
