Here's mine
Looks like you have it figured out....I still do not understand the american system.. The smaller the number (wire gauge), the bigger the wire...
Metric system: A bigger number means a bigger wire (square section/area)
Jim I woulda or shoulda but I wuz taking baby steps with the Skipper as case in point do you remember how many pictures of his feet were posted before he discovered shoes?Also about the crimping. George told me to dip the wire in anti-seize before crimping too. I would think copper based would be best. George you're slipping, you should have mentioned this but I guess you're so taken back by the tools getting launched and now the air rifle that you were overwhelmed. And your grief for missing JH.
How often do you go to the dentist?No crimpers, here...I just bite down with moderate pressure......
Those are big boy tools. I assume they ratchet up tight??Here's mine
Oh yeah. But it does have a quick release if you do something stupid.Those are big boy tools. I assume they ratchet up tight??
WSS
John's divorced but has two kids in College so I guess it still works out the same.See Skipper John has a good crimper is married and has kids, so your argument dont work.
Often enough to have put one of his kids through college!...How often do you go to the dentist?![]()
Good addition that quick release. LOLOh yeah. But it does have a quick release if you do something stupid.
You don't want to get your finger in there.
Thanks, Tommy. Today was the virgin run with the fans. Everything seemed to go alright, but I have temperature questions for another thread. So BOTL!WOW....:surprise:
Professional results. Looks good. Post back a review on the workings of those. I would like to go that route soon.
The fact that you care about your work is probably the no.1 factor in the success.
WSS
Good God! Sorta makes me feel inadequate, John. Did you have to show that?Here's mine
Just because you can't show your feet due to your old, cracked toenails ain't no reason tuh get on me! My toes is bee-u-ti-full! (Stick poke)Jim I woulda or shoulda but I wuz taking baby steps with the Skipper as case in point do you remember how many pictures of his feet were posted before he discovered shoes?
Scott's still married with one kid out of college, one kid still in college, and two more to go! That's why I don't have kickbutt crimpers! :laugh:John's divorced but has two kids in College so I guess it still works out the same.
I guess it's not how much force you mash it down as to what the final crimp size or height it should be.So how hard should you mash down on the connector?
I didn't realize the connectors I'm using had adhesive in them. But I am using the same ones. Thanks for the information. I don't think I have ever NOT broken through the plastic when I crimped a wire! And I've been there with the bilge problem. We had the same boat PO!Skerr, back to your original question, I see. Hopefully this is the answer:
I use the insulated connectors with the heat shrink/adhesive (weatherproof) insulation available at any auto supply. I use the non-insul (stake) position on my cheap crimper or on my Klein crimper, just enough to crimp the wire, but not so much as to punch through the insulation. (Fith pic in post #34) There is your electrical connection. Then I heat shrink each end with a two dollar fire starter butane match. The glue melts, the plastic shrinks (stop just before it turns black), and there is your mechanical connection. Just did that on my bilge pump to float switch wires (in my boat, not the Jeep, only once did I need a bilge pump in the Jeep). The PO just used non-weatherproof crimps and it almost sank my boat when the float switch wire totally corroded off, simultaneously, in two places.
