1 - 8 of 8 Posts
Nailing down some mods I'd like to do when I tear down to do rust repair and paint.
Any reason to not shave the drip rail?
Passenger side is already mangled from a tree so I figure it's an extra inch per side of clearance.
Anyone done this and if so how'd it go?
probably wrenchin instead of wheelin
1974 Jeep CJ-6
IIRC the drip rail down the side is where the 2 halves are spot welded together, if you cut them off, your windshield would come apart on the vertical seams.
Ah, vertical drip rail. Copy!
Yes, that has the spot welds for the two halves of the frame.
Hoss
Yeah I figured they'd have to be welded as usually drip rails are a seam spot.
I've got two windshield frames so I guess if it doesn't work out I'm not completely SOL.
There are still spot welds along the top and bottom so it wouldn't actually fall apart but I wouldn't just cut it and leave it. It would get welded up and metal finished before paint.
1974 Jeep CJ-6
Still trying to figure out the wheeling with a windshield on.... guess that is why my wheeler has pre 74 winshield frame and hinges. Just lift off the windshield, hard to hit a tree with it if it is back in the truck at the trailhead.
i usually drive the cj to the trailhead, rather than trailer it, due to proximity of trails to my residence. i also prefer not to get poked/smacked in the face by the branches and brush overhanging the roads while wheeling.
1 - 8 of 8 Posts
