She has an affinity for her WK but wants to use it a bit more aggressively out in the desert so we decided to build it up a bit. It has plenty of power with the 5.7 in there but it was seriously lacking in the suspension department. She had a spacer lift and wheel spacers to give it the look but limited travel, especially in droop, it leaves something to be desired. So I decided to go ahead and get started on the front suspension. I got the design nearly done and I will be building this over the next 3-4 weeks. It is +2" per side so longer axles are also in order. Looking forward to no needing wheel spacers on the front anymore and really looking forward to the extra travel. I will be using Fox 2.5 race coilovers in the front and fabricating all the suspension components from 4130 chromoly.
Once I get this done I will move onto the rear suspension to see what we want to do there. Wish me luck. :grin2:
