I have a Jeep Wrangler jk 2010 3.8l v6. My lift kit is 4 inches and I have 37x12.5r17 Mickey Thompson Baja Atz tires. We recently got 28 inches of snow and this was my first major snowfall with this car (I bought it this summer) My friends and I drove to a parking lot to drive around through the deep snow and they drove through it no problem In a Jeep Patriot and truck and I immediately got stuck in an area of just 4 inches of snow. Keep in mind I recently found out that the previous owner for some strange reason has a different gear ratio in the front axle than the back so I didn’t use 4wd but stayed in 2H. I am getting the gears changed to 5.13.1 in the front this coming week to match my back axle but I was suprised at how bad the wrangler drives in 2wd regardless. When we have even just 2 inches of snow on the streets it gets no traction and slides everywhere. again keep in mind I haven’t been able to use 4wd yet so I’m sure it will perform better but I’m still suprised as to how bad it drives right now. I have found some explanations as to why it may be so bad on this forum and from friends. 1 being my tires are wide and not optimal for snow as thinner tires do better. I’ve also heard because wranglers have such a short distance from axle to axle they are prone to slip and slide as well. Just curious to hear anyones thoughts as to if this is normal.
