1 - 5 of 5 Posts
While doing some coolant flush work under the hood, I noticed this part has a very noticeable tick while idling. For some time now I was convinced I had to investigate an exhaust manifold leak or a loud lifter, but this little tower is crazy loud.
1) what is the part? acts like some type of a solenoid .
2) is the ticking okay? Ticks in about 1/2 second intervals.
Hood Automotive tire Motor vehicle Automotive design Automotive exterior
I can send a clip if it's needed but thought I'd start with pic. It's just in front of the brake res..
Purge solenoid for the vapor canister system. When the engine reaches a certain temp and or an amount of run time the pcm( computer) will cycle it on and off. It will make a ticking type sound. It is perfectly normal to hear it click .
'01 Limited 4.7L Quadradrive
Mine typically ticks until the engine warms up and then it stops.
Mopar Nut
I replaced mine when I noticed it ticking, assuming it was sticky or worn. New one sounded no different, then I found here on the forum that it is normal. Sounds like a single sticky lifter. Will tick at idle, on a cold engine, will shut up once everything is up to temp....
Reactions: detroitrust
1 - 5 of 5 Posts
