What is this broken parts name?
453 7
Wood Tints and shades Metal Automotive wheel system Soil
Tire Wheel Automotive tire Tread Hood
1 - 8 of 8 Posts
Real Jeeps have dents
There are several different diameters. Check before you buy
Knew front sway bars had different diameters but this is the first time hearing about the rear.
Not to long ago replaced mine with some from my Napa.
But there is one thing I did run into.
The sway bar having rotted a bit causing the diameter to be smaller on one side.
Used a piece of hose on the end of it to take up the "slack".
LOL.
Look close at the second picture.
LOL.
I've used electrical tape on alot of caravan sway bars for that same reason.
1994 Jeep Cherokee XJ 2WD 4.0l AW4
Rear sway bar? I've got the perfect fix for that. Pull it off, and throw it in the garbage. You probably won't even notice that it's gone.I can't tell any difference on my '94.
1 - 8 of 8 Posts
