They're there 🤷♂️Pic did not post
-----JEEPFELLER
It's too hard to get under there with one working arm so I can't go look, but I bet you're right. It sure looks cracked. It's weird it knocked out a perfectly square chunk.almost like the tit is separate from the yoke.End of the cross bound up against the tit after it spit out the cap, shaft went around and it pushed the cross into the tit and broke it off. Can't tell real well, but did the yoke crack between the bolt hole and where the tit was?
Bout 30 seconds.Looks like it rose to the temperature of the center of the Sun on the yoke surface.
How long did it scream or vibrate like crazy before you discovered it?
------JEEPFELLER
You can mark the pinion nut to the shaft, count rotations when you take the nut off and put it back together without changing the crush sleeve.Bout 30 seconds.
If I have to change the crush sleeve and drain the diff anyway I might as well amass parts to do the rear gears anyway. I'll think about it.
This is true if the same has not been done before. I will add to it that you need to remove the rear brakes and measure the preload of the entire rotating mass in inch pounds with a dial or flex type wrench. You then increase the preload by 3 to 5 inch pounds to make sure that you regained crush on the sleeve but did not over tighten the preload on the bearings. Marking the nut and shaft is not reliable when you are installing a new part such as a yoke. They are not guaranteed to be the exact same dimensionally. Stuff is manufactured to tolerances. Also. Many yokes come as a kit with a new washer and nut.You can mark the pinion nut to the shaft, count rotations when you take the nut off and put it back together without changing the crush sleeve.
Only way to go.Time for an upgrade View attachment 4150154
