thanks, there rugid ridge d-windows (15x8) and 33x12.5 km2s.
thanks, there rugid ridge d-windows (15x8) and 33x12.5 km2s.What rims and tires do you have? You got a sick XJ
and check out that oil pressure! :thumbsup:
I ordered a drop pitman, now people are saying that if i drop the pitman arm, then i have to drop the track bar to have the same geometry. I might just let the guy whose doing the alignment decide, as that is all he does for a living, only trucks. ( different shop then the first time lol)phfister said:Nope. Lol.
You need to clean your lens , it makes your rig look all muddy ... :laugh:did some late night wheelin! gotta say new phone takes kick *** pics!!
Do you have any wheeling where you are now?Oregon187 said:Noice! :thumbsup: I used to live in the middle of nowhere in Oregon. Our house was at the end of 6 miles of dirt roads and to the north of us was thousands of acres of high desert federal land. It was a great wheeling area. I didn't have a Jeep back then, but my Ram did okay. Now I wish I was back out there. Indiana sucks!
You forgot to weld and grind the holes smooth...Plasti dipped dis
You could have saved $150 by building one and accomplishing the same "feel" in the shifter...
Also forgot to buy a welder SHOOT. Lmaoibjeepin95 said:You forgot to weld and grind the holes smooth...
I actually thought of yours when I saw that post lolibjeepin95 said:You could have saved $150 by building one and accomplishing the same "feel" in the shifter...
Looks good! Do I spot door cancer?View attachment 554167
Haven't had a chance to check clearance yet, but so far so good!
Sent from an iThingy using JeepForum
Badass. This is the Ballistic truss, correct?In Dana 30 I trussed
Yes sir. Required cutting it up a bit to work with the stock UCA brackets. And the little piece they give that is on the drivers side seemed useless to me so I left it off. Barely even used any of the 1/4" because most of the top side of it is the 1/8" bent over from the front piece. Only the part that would go over the diff housing is 1/4". Which I barely usedibjeepin95 said:Badass. This is the Ballistic truss, correct?
