That's what I thought, are leafs usually 150 a piece or am I reading this wrong...Climbit said:get rid of the blocks.
Haha, thanks. Warn sent me the wrong hook so im waiting for the right one to get hereSFR yours looks great... although you might want to double up on that ziptie![]()
x2. I just kind of went along with it. I feel like I would get more flex w/o blocks for some reason though.Luke95 said:Hey forgive me but I have to ask whats so bad about blocks?
Im neutral and ready to be biased.
For about 65 bucks you can get 3-4 inches of lift. (i spent 20$ on my bastard pack and 30$ on new ubolts plus a few bucks for pb blaster) I ran an xj main leaf and a whole s10 blazer pack underneath it and had 3+ inches lift from it plus a 1.5 inch shackle. It didn't ride that bad and it was really cheap and effective.At 285 a pair forget it. I'm just going replace the stock leafs with either new or used ones. Maybe not the smartest decision, but I'm balling on a budget.
:rofl:
Promotes axle wrapLuke95 said:Hey forgive me but I have to ask whats so bad about blocks?
Sounds tempting, but I wouldn't know what the hell I was doing, lolShowtime3492 said:For about 65 bucks you can get 3-4 inches of lift. (i spent 20$ on my bastard pack and 30$ on new ubolts plus a few bucks for pb blaster) I ran an xj main leaf and a whole s10 blazer pack underneath it and had 3+ inches lift from it plus a 1.5 inch shackle. It didn't ride that bad and it was really cheap and effective.
Not worried about that because a month or two ago I added a spacer lift and when I put the bolts back in I anti-seized them ALL. Then i replaced the shocks, like a month ago, and anti-seized all those too. So it should be pretty easy.BlueBadger said:Start the PB soakfest now!!
What do I need to do to break them loose?xj_noob said:Not worried about that because a month or two ago I added a spacer lift and when I put the bolts back in I anti-seized them ALL. Then i replaced the shocks, like a month ago, and anti-seized all those too. So it should be pretty easy.![]()
Get some PB blaster and a breaker bar. That's how I did it. And then I just prayed that the bolts don't break and they didnt.MattBillyTayloe said:What do I need to do to break them loose?
The addition of the block is like adding length to a ratchet. If you think of the centering pin as the pivot, an the lever going down to the center of the axle, the longer that lever, the easier to turn what every your trying to twist. That being said, when you step on the gas or the brake, an your axle is further from the leaf centering pin, its going to have an easier time bending the leaf which results in whats called axle wrap.Hey forgive me but I have to ask whats so bad about blocks?
http://www.knowwhere2jeep.com/rubicon-express-rear-leaf-spring-xj-3-5.htmlThat's what I thought, are leafs usually 150 a piece or am I reading this wrong...
Lol I know what they are. Every XJ I've had the swaybars were the first things to go in the trash.RacerX said:It's actually a misnomer
What they are is Stabilizers or stabilizer bars, they are actually for anti-sway while turning (to keep the tires under the vehicle)
They stabilize the steering geometry. Here is a good explanation:
http://auto.howstuffworks.com/question432.htm
I love my Action Fab bumper! I'm in the same place as you, I need a winch for mine lolClimbit said:my actionfab front bumper sits an inch further back than that one.
all it needs is a winch...
