I fixed my lock mechanism on the front passenger door.
Its not to bad, I did it for a few months, I still have the tcase drop blocks somewhere if you want them. Also, see any XJs with skid plates?Joshharris98xj said:Went to the junk yard because they got a new 97 untouched and spotless white xj pulled the parts I needed I have to go back for the DS, I know I shouldn't and will get flamed for this but I'm going to try and run a t case drop and shims for about a week because I won't be able to do my hack n tap at the same time. Anyone limp around with a t case drop for a little while on 5.5?
I work with a dude that's running a 1" drop on a 4.5 permanently. No issues so far.Joshharris98xj said:Went to the junk yard because they got a new 97 untouched and spotless white xj pulled the parts I needed I have to go back for the DS, I know I shouldn't and will get flamed for this but I'm going to try and run a t case drop and shims for about a week because I won't be able to do my hack n tap at the same time. Anyone limp around with a t case drop for a little while on 5.5?
I ran a tcase drop and 4* shim with a 6" lift for a little bit until I could afford the sye.Went to the junk yard because they got a new 97 untouched and spotless white xj pulled the parts I needed I have to go back for the DS, I know I shouldn't and will get flamed for this but I'm going to try and run a t case drop and shims for about a week because I won't be able to do my hack n tap at the same time. Anyone limp around with a t case drop for a little while on 5.5?
I want them! And no sure didn't I would have grabbed it if sochriskeenan said:Its not to bad, I did it for a few months, I still have the tcase drop blocks somewhere if you want them. Also, see any XJs with skid plates?
YoureverydayXJ said:I work with a dude that's running a 1" drop on a 4.5 permanently. No issues so far.
Lucky guy right there, thank god I was a little worried, it won't e permanent what size shims should I go with to e on the safe sidealexrule123 said:I ran a tcase drop and 4* shim with a 6" lift for a little bit until I could afford the sye.
Bring it back to them to make right, their fault their problem.Back_In_Black said:The head gasket was pretty nasty, but didn't have any cracks. They had a problem getting the new intake to mount to the dowel pins, and accidentally broke the end off of the mounting hole on the intake, I crawled under it myself, and could not find any leaks or holes, but It still make me wonder....and since they broke it they gave it to me for free.
The only issue I have now is that it has a bit of a high idle, and it is consistently getting higher, about 1k Rpms now, but I will keep an eye on it, I hope it's not because of the dowel pin mount being gone. Besides that it runs perfectly at operating temp, and has no problems.
I will never take it back to them for engine work.Bring it back to them to make right, their fault their problem.
Looked like in the pic it was just a bunch of guys that work on jeeps not professionals, who knows they may be maybe not they might be able to do awesome work but what did you expectBack_In_Black said:I will never take it back to them for engine work.
they do great suspension and axle stuff, but I'm not too impressed with their engine skills.
Im going to give it a tune up, and diagnose the high rpm problem this weekend, as well as double check their work.
I doubt the broken tab is any issue, but I will find out.
nah, they know their stuff, and breaking the intake was an accident, but I'm just not a fan of their style, or anyone elses for that matter.Looked like in the pic it was just a bunch of guys that work on jeeps not professionals, who knows they may be maybe not they might be able to do awesome work but what did you expect
I broke the same spot on my last xj didn't have any issues, clean the iac and double check to se if the intake is seatedBack_In_Black said:nah, they know their stuff, and breaking the intake was an accident, but I'm just not a fan of their style, or anyone elses for that matter.
roger that.I broke the same spot on my last xj didn't have any issues, clean the iac and double check to se if the intake is seated
4* shims and sye. It looks better in the pic than real lift. Still get vibes. Might try 6* Idk.alexrule123 said:I ran a tcase drop and 4* shim with a 6" lift for a little bit until I could afford the sye.
cool, i'll hit you up on FB when i find them, you might need the bolts though, i'll have to look through my boxes on junkI want them! And no sure didn't I would have grabbed it if so
Spokes said:4* shims and sye. It looks better in the pic than real lift. Still get vibes. Might try 6* Idk.
Josh you should be fine for a while.
All I did today was drove mine. Gonna order steering for it byMonday![]()
They look like they have a nice set up you know What they say if you want something done right do it yourselfchriskeenan said:cool, i'll hit you up on FB when i find them, you might need the bolts though, i'll have to look through my boxes on junk
