Checked plugs. For some reason cylinder 4 and 5 plugs are too lean for my liking
If you have access to good equipment why not do the paint job yourself? You need clean and dry air to begin with then after that a good spray gun and some hand tools. It's allot of work but if your metal is all in good shape it would help keep it that way for a long time.Both of you guys have really good looking paint jobs. I would love to have mine professionally painted, but I don't know if im willing to drop that much coin to do it. Althought at this point with all the mechanicals being nearly perfect it wouldn't make much sense to put a crappy paint job on it. Might have to splurge.
When you are ready to sell it, let me know. I guess I'm saying "I want first dibs" on your hardtop. The one I have is an early heavy plastic version, and I have already decided I want the version that my 1986 CJ-7 came with. Plus, it would be kinda nice to buy something someone else did the work on for a change...and yours probably has the interior light in the back, which is a feature I want.Brought home my hardtop that was stored at our works warehouse for about 8 years. Plan on refurbishing it with paint and then selling it. It's completely in tact and the rear hatch is not rusted at all and the spring struts still work. Just needs a new rear hatch lock.
Keith will you be taking the time to document the top work?Brought home my hardtop that was stored at our works warehouse for about 8 years. Plan on refurbishing it with paint and then selling it. It's completely in tact and the rear hatch is not rusted at all and the spring struts still work. Just needs a new rear hatch lock.
Yes it does, but needs replaced. You can get them from a Chevy pickup supply house for about 20 bucks. They are the same ones Jeep used and are from GM trucks 1960-1972. Can be found here: https://www.classicparts.com/1960-7...I_47alJjH5gIVj4TICh0pyQTqEAkYBiABEgItkvD_BwE#...and yours probably has the interior light in the back, which is a feature I want.
One doesn't see old Internationals in junkyards much anymore, but the old International Travelall (sort of like a Suburban) had two of those same dome lights used in CJ7 hard tops.You can get them from a Chevy pickup supply house for about 20 bucks. They are the same ones Jeep used and are from GM trucks 1960-1972.
Probably not. I have yet to finish upholstering my OEM seats for the front on a thread I started awhile back. Too many house projects at the moment.Keith will you be taking the time to document the top work?
This is what I want to do, to feed my warmed-up Mopar 4.0 (4.7) inline six Jeep engine. It's a double upgrade at the same time. Your picture looks like the OEM plastic 20 gallon tank has steel inserts for the new fuel pickup/pump/sending unit. My CJ-7 currently has the OEM 15 gallon steel tank. I know I need to acquire an OEM 20 gallon plastic tank and skid plate. Is the original tank opening (and steel inserts) used when using the Novak pickup? Can you share more info on your conversion? Thanks.Converted my CJ-7 OEM 20 Gal tank to use the YJ Fuel sender system. I converted to in-tnak fuel pump using the NOVAK sender, however it is a pain when you have to change the pump and I have no end of troubles with fuel gauge and those cheap CJ-7 after market senders.
Rebuilt the JY sender since I use a higher pressure pump, also had to lengthen it and shift the pump location so that it sat in the slight depression in the tank (didn't know that was there before), and reshape the float arm. Not super pretty, but came out OK.
Need to get to the station and fill the tank to see if the sender and fuel gauge now work reliably. I have the Speed Hut Jeep guage set, so I can calibrate the sender to the fuel guage.
The Novak in-tank pump uses a modified CJ-7 after-market fuel sender. These units have a round mounting plate and fit in the circular hole and are held in with the large plastic nut (similar to the 15 gallon tank).This is what I want to do, to feed my warmed-up Mopar 4.0 (4.7) inline six Jeep engine. It's a double upgrade at the same time. Your picture looks like the OEM plastic 20 gallon tank has steel inserts for the new fuel pickup/pump/sending unit. My CJ-7 currently has the OEM 15 gallon steel tank. I know I need to acquire an OEM 20 gallon plastic tank and skid plate. Is the original tank opening (and steel inserts) used when using the Novak pickup? Can you share more info on your conversion? Thanks.
