1 - 4 of 4 Posts
2003 4.0 Laredo, 42RE transmission.
This is a two wire cable going to the overdrive unit area, behind the transmission pan. It is slowly bleeding transmission fluid...
I also have an inconsistent Park/Neutral switch CEL. Is this related? I think not bc according to the manual that cable looks like this:
Well if it is from your OD, and is only a two wire connector then it is likely just a switch that is for a dash light. If the oil is leaking internally, then a replacement is in order.
1 - 4 of 4 Posts
