Why not just go 4 speed atlas?you can get a Klune
a D300 + Klune will fit in a TJ. So should an Atlas + Klune. A supershort NP231 SYE + Klune may fit too.
4-speed Atlas: $2875Why not just go 4 speed atlas?
I would rather spend a few hundred more and have a gear driven transfer case, and I only had to shorten the rear drive line a half inch, so I don't think changing the drivetrain length was a big deal in my case.4-speed Atlas: $2875
3-speed Stak: $2900
Klune: $2600
^^damn thats expensive.
My idea:
Rubicon NV241J: $800-1000
AA Rubicrawler: $1600
Total: $2400-2600
Saves a few hundred bucks and doesn't change the drivetrain length at all.
If I had a 241 I wouldn't replace it for an Atlas, but by the time you buy a used 241 and add a rubicrawler to it its getting too close to the price of a brand new atlas 4 me.:thumbsup:I'll be going after the rubicrawler also.. wont' need any new driveshafts, shift linkages... ect.
I'd say since I havn't busted the 241 yet, it'll prolly last a long time...
I do like the atlas tho.. that's for sure
but you can put a 241 in for the same price as a SYE installed. Run it for several years, then add a Rubicrawler for less than half the cost of Atlas 4-speed once you figure new driveshafts, tub hammering and linkages. I can't afford a Rubicrawler or an Atlas right now. But a NV241J + $20 used Rubicon front driveshaft + 1310/1330 u-joint + Tom Woods rear shaft is doable, and will work forever if I want. Once I do get the money saved for a Rubicrawler, I can install it with zero changes to the drivetrain.If I had a 241 I wouldn't replace it for an Atlas, but by the time you buy a used 241 and add a rubicrawler to it its getting too close to the price of a brand new atlas 4 me.:thumbsup:
Interesting, i'll look into that. I was just going to fabricate something if necessary or bend the stock linkage to make it work. Do you have any pics of the cable shifter?What do you have planned for the 241 linkage? Factory or aftermarket? I thought about reusing my factory stuff, but I did not like the feel of the engagement. After having the Novak 231 shifter I went with their new 241 cable shifter.
I can't find that on Novak's website.Here is the only picture I have of it.
It uses the stock lever so you don't have to bend the shift arm like the old models.
I just got this part and installed it. I can confirm it is the VSS for a Rubi t-case.Found the Vehicle Speed Sensor - AIRTEX Part # 5S4942
