What type of rattle and where?Did you check your own codes?Did it throw any?Could be a heat shield loose,bad cat,t case linkage,etc..
Having a little "play" while in 2HI is normal, but if the rattling goes away or becomes less noticable while holding it up in 2HI then you know it's your transfer case linkage. There are some aftermarket replacements you can buy or you can also relocate it from the body and place it on the transfer case with a kit.I just ran out and checked it, there seems to be about a 1/2 inch of play before the pressure starts where you would pull to engage 4 HI.
so this seems like ti could be causing the rattle.
Well... you can either replace the bushings or relocate it. I think reolcating it would be the better option since you plan on a BL. I don't know the "best" aftermarket adapters or parts but here's some as an example which you can find through Quadratec...B2CARPEN, what bracket would I need, right now the jeep is stock but very shortly I plan on putting on a 1"
BL, 1" MML, and a 3.25" RC suspension lift. I would rather correct the problem then just brace something underneith the handle if at all possible
That's funny... I'm doing the exact same mods. I already have my RC 3.25" kit ordered :cheers2:B2CARPEN, what bracket would I need, right now the jeep is stock but very shortly I plan on putting on a 1"
No Prob! I hope the relocation kit helps out your rattle issues. Let me know how it all works out since I might consider doing it as well (My kodiak tin isn't holding up like it use to :laughthank you everyone for all of the help, if taking up the slack removes the rattle then I will be looking for the bracket very shortly
expect the lift kit to ship and be delivered very fast, it seemed that I had mine in no time, now the only problem is going to be having nice weather for an entire weekend to get underneith it and get it installed
Agree... and 100% ANNOYING AS HELL :rofl::rofl:our 05 lj rattles in the tranny as well when the clutch
pedal is out and its in neutral. ive read on here that
its 100% normal. i had the fluid changed and it was
in good shape and at a good level.
