Hi all,
One day my Jeep made a big clunk when coming to a standstill and then started making this noise at low speeds:
It's related to wheel rotation speed but is not one 'click' per wheel rotation - it is much faster than that.
Here's another vid, a bit faster
Removing the front driveshaft reduced the volume of the noise by about 95%. If I listen VERY carefully, when things are very quiet I can sometimes hear the clunk noise.
Here's what I've done (some of this stuff needed doing anyway)
Replaced CVs and shafts of front axle
Replaced CV on front DS
Replaced pinion bearing at the back of front diff
Changed Transfer case fluid
Put the front driveshaft back on and absolutely no change - noise still as present as ever so promptly removed it again.
I'm currently driving around with RWD only and pondering what to do next. The Jeep drives really nicely in rear wheel drive (where I live and drive I do a lot of full lock turning, 3 point turns, parallel parking etc) so I notice a difference - it's happier to do these turns and I don't feel like I'm fighting it.
I always that was just part of having a NV247 but my mechanic commented that when he test drove it with the front DS on, it felt like it was getting thrown around too much by undulations in the road, compared to his own WJ which has a similar set up to mine. He said he's experienced a similar sensation once before on a Range Rover with a binding centre diff.
I feel it it is something up with my transfer case - what do you guys think?
Thanks,
Fram
Thanks,
Fram
