Torq Masters Aussie Locker [$650]
19517 Views 42 Replies 43 Participants Last post by  YJ475
2
Product Information
Price $650
Rating 4
Average Price $260.74
Manufacturer Torq Masters
Recommended Yes: 42 / No: 0
The Aussie Locker is a fully automatic and precision manufactured automatic differential locking device that does not require any manual operation to activate. It does not require any switches, external compressors, electrical cables, air lines, or pneumatic controls. It is positive locking, meaning there is no slippage when locked. There is a mechanically solid engagement of all parts. In contrast a limited slip differential is not positive locking and does allow slippage and one wheel "spin up" i.e. the spinning of one wheel at twice the differential speed while the other wheel having traction remains motionless. With the "Aussie Locker" you get 100% of drive and traction to both wheels.
See less See more
1 - 20 of 43 Posts
Rating 4
Pros In-expensive, quiet, easy to install
Cons non selectable
Recommended yes
Comments: I love mine in the front, it works flawlessly. I am about to install one in the rear as well. installation is not a big deal and can be done in your driveway!
See less See more
Rating 5
Pros Cheap & easy to install.
Cons Occasional clinks and clanks.
Recommended yes
Comments: Just put an Aussie locker in my rear D44. So far, I love it. It occasionally clicks and clanks around turns, but that should be expected from a lunchbox locker in the rear.
See less See more
Rating 5
Pros Affordable, great quality
Cons none
Recommended yes
Comments: Works perfect for a lunchbox locker. Have it in the D30.
See less See more
Price $230
Rating 5
Pros best lunchbox locker for the money
Cons none
Recommended yes
Comments: this thing is remarkable, only thing I would suggest is to upgrade your axles and ujoints. This thing offers some serious traction
See less See more
Rating 4
Pros Great traction, most affordable lunchbox locker, works everytime
Cons occasionally sounds like it is binding, but normal for lunchbox locker
Recommended yes
Comments: I have had an Aussie Locker in my front D30 for about a year and it has worked great. Very easy to install, took me about 1 and a half hours from lifting the vehilce to cleanup after it was installed. The only negative I had was it was kinda noisey compared to what other had said about it being silent and not even noticable. However after about 6-7 months it quited down and is now completely quiet. Breakin period I am guessing.
See less See more
Price $250
Rating 4
Pros price, DIY installation, cheap locker, no tire size limitations
Cons noisy, back end gets squirrelly in snow
Recommended yes
Comments: I have an aussie in my rear XJ dana 44. It's a little more of a chore to put these in axle's that have "thick" ring gears (dana 44), because the cross shaft will not clear the ring gear. That means you have to pull the carrier and remove the ring gear from the differential. Not a biggie, but a little more labor intensive that some may have you believe.
It works great for offroad. You do have to adjust your on-road driving slightly. I have noticed the jeep pulling slightly to the outside of a turn as I straighten up, especially if you are accelerating hard. Plus they are loud when they are first installed. Mine has only been in for two months now and maybe 400 miles, so it may quiet down after break in.
As with any full time locker, you have to be careful in rain and snow as the rear end will break loose easily and send you sideways. Side hill traction in slippery situations can also be tricky. With both tires spinning, it want to slide downhill.
I always get strange looks when I'm turning in parking lots. People thing you jeep is falling apart, but in a way, they're right, just for the wrong reasons.
See less See more
Rating 4
Pros dont notice it when in 2-wheel, but i get excellent traction in 4 wheel
Cons none yet
Recommended yes
Comments: very simple install (dana 30 front end). i cannot tell that i have a locker when im driving on the street, but once its in 4 wheel drive, you can definitely know the difference!
See less See more
Rating 4
Pros Excellent traction, great price, outstanding customer service
Cons gets a bit bucky when turning in to parking spots (no fault of Aussie, general fault of lunchbox style)
Recommended yes
Comments: Installed it in two hours including dinner into a AMC 20 rear. Nice clean easy to understand instructions, and customer service was excellent. Manners on road are more than acceptable for a lunchbox locker - off road is awsome.
See less See more
Rating 5
Pros great traction
Cons a little rattly in turns
Recommended yes
Comments: I had one in the front D30 before I went to ARBs. From a traction standpoint, it works every bit as good as an ARB at a fraction of the cost. Install was pretty straightforward, even for a C- grade driveway mechanic like me.
See less See more
Price $249
Rating 4
Pros cost
Cons instructions
Recommended yes
Comments: installed one in my Dana 30 last spring. Instructions could be better, but was able to download some lunchbox locker installation notes from the internet which helped. total install time was 3 hours. has worked flawlessly, and almost invisible in 2wd.
See less See more
Price $249
Rating 4
Pros Price, Self Install
Cons Dana 35 complications, Manual
Recommended yes
Comments: I just finished the install on my Dana 35 and I ended up having to shim my thrust washers and grind my carrier to get the right gaps and have every thing fit in there. A big tip is to look up the specialized install manual on their website. The manual that came with the locker wasn't great, especially with the explanation of the gap measurements(.006-.020 gap PER SIDE means a total gap of .012-.040 when measuring the axle gears and spacers), but other than that it was relatively easy.
See less See more
Price $250
Rating 5
Pros Awesome offroad, and onroad and great price!
Cons None so far but slight clicking while turning tight might be a "con" for others
Recommended yes
Comments: The aussie is one of my favorite upgrades :rtft: . as far as hill/rock climbing I can go up stuff with ease that my buddies with much bigger tires and unlocked front ends have ALOT of trouble doing (they need to get some speed while I can just crawl over). In mud, it's nice to be able to "saw" the wheels back and forth when stuck and have both of the tires moving :D
the install was very simple, check out my post in this thread:
http://www.jeepforum.com/forum/showpost.php?p=3365186&postcount=4
[http://www.jeepforum.com/forum/showthread.php?t=380096&highlight=aussie
I would choose the aussie over the lockright as I've NEVER heard anyone complain about the aussie but I have heard people complain about the lockrite.
also aussie locker stands behind their product and have a awesome warranty.
I bought mine from Dave at www.Northridge4x4.com
It shipped fast and they have great customer service!
-Matt
http://i81.photobucket.com/albums/j202/mattorias/jeep/Offroading/Lost%20Lake/8-12-07/CIMG1113.jpg
http://i81.photobucket.com/albums/j202/mattorias/jeep/Offroading/The%20Hump/3-18-07/CIMG0767.jpg
See less See more
Rating 5
Pros Performance-to-Price
Cons You'll can take on more aggressive trails -- so you might see more body damage, and need more repairs and mods than you had in your budget (haha)
Recommended yes
Comments: Had an Aussie in the front end since mid-2006. Works great. Probably doing the rear-end also.
I used Mobil 1 and now Royal Purple synthetics in the diffs and I've never heard any noise since Day 1 with the Aussie. Perhaps the lower friction oils help there.
See less See more
Rating 5
Pros Cheap and easy to install and it's invisible
Recommended yes
Comments: Great locker. I have it in my D30. Like I say, it's invisible, you don't know it's there untill you need it...
Price $250
Rating 4
Pros ease of install, cost to performance ratio, quality of product
Cons ocasional clunks, makes winter driving "different" :)
Recommended yes
Comments: mounted in a ford 8.8.
The install is a bit tight and the springs were tricky to get in there.
Overall this is the best higher dollar purchase I have made for the YJ.
Traction is always there: wet, dry, winter, summer, sand, mud, highway, parking lot.
See less See more
Price $250
Rating 4
Recommended yes
Comments: I love it.
Price $130
Rating 5
Recommended yes
Comments: Easy install, great product for the money.
Price $289
Rating 4
Recommended yes
Comments: Still waiting to get it!!!
Price $400
Rating 5
Recommended yes
Comments: excellent
1 - 20 of 43 Posts
