So my XJ is an ex USFS truck that already has a NMO cable and through roof mount, but no antenna or radio. The lower dash has holes drilled to mount the CB and mic. The antenna mount is old and has been exposed to weather so not sure if its still okay or not. Since there's already a hole in the roof and my headliner is off (to replace it) I'm thinking why not replace the antenna mount with a new one before putting the new headliner up. Adding the radio will be easy since it will cover up the holes in the lower dash, but adding the antenna will be a little harder. A roof rack covers the antenna mount so I would need to do an NMO to cable adapter above the roof, then run a cable under the rack and mount an antenna in the front right of the rack. I'm not a CB expert so not sure how well that will work. I priced the parts and it's not expensive and neither is a good CB radio. Still not sure it's worth doing because the CB will not get much use, but on the other hand the hole is in the roof and holes in the dash, and since it's a ex USFS truck it will look right at home. Any thoughts, specifically on the the antenna mounting or anything else?
