The harness and computer I got with the engine was for DBW I have ordered parts to convert it to DBC. I didn’t want to deal with trimming down my own harness, so I ordered a standalone harness for DBC. I will probably end up purchasing the correct PCM to match.
the heads are at the machine shop having a valve job and resurface. I’m the meantime I have been cleaning and painting the block. Also been ordering a pile of parts. I decided to switch to flat top pistons, all new bearings, new lifter, new rings, valve rocker trunnion upgrade, new camshaft, new valve springs, and some other crap I have forgot to mention. Once I get the engine in the chassis I’ll be able to tell if I will need/want to order a different oil pan
I ordered clutch, flywheel, and slave cylinder for a 6.0 ls with nv4500. I compared my ls flywheel to a sbc350 flywheel and there was a noticeable difference between the two. I have a piece of oil impregnated bronze for a pilot bearing if need be.
Right before I started the swap I had ordered a set of triple bypass shocks for the front and they finally came in.
