looks great - can't wait to see the build
Money is going to be the main deterrent from finishing this year. I expect by next spring I'll have it somewhat back together and drivable.BagusJeep said:Looks good, rapid progress, expect completion this year???
Ive read some decent reviews on the HF welders... Nothing special, but it seems like it would get the job done, especially since they are smaller holes... Plus the whole inside and underside is getting coated and lined, so it doesnt have to be pretty.Lots of success stories with the HF MIGs, although I am biased against them personally. You might shoot Mike (Coiz) a PM... he used one on his build and was happy with it.
Bastard. If only I were a bit closer to Houston....Signing in to follow this one. I cant be of much help on the welder front either as we have a 110 and 220V miiller mig at work I can steal for a weekend when I need to weld something on mine...
careful with coating it...that stuff is a mess if you have to remove it later. We spent HOURS carefully patching the rust inside the tub and priming before spraying my bedliner down... It was a TON of work but I plan on keeping my rig for at least 30yrs so I dont want to deal with it again any time soon.Ive read some decent reviews on the HF welders... Nothing special, but it seems like it would get the job done, especially since they are smaller holes... Plus the whole inside and underside is getting coated and lined, so it doesnt have to be pretty.
Im in the same boat. I want this to last for awhile, so there will be a TON of prepping and patching to make sure every bit of rust is gone and every weak spot is repaired or reinforced. The body is in such good shape (compared to other I have seen) that I would rather not spend the money on a replacement tub if I can repair this one... Plus it keeps it original, and thats really what im shooting for.careful with coating it...that stuff is a mess if you have to remove it later. We spent HOURS carefully patching the rust inside the tub and priming before spraying my bedliner down... It was a TON of work but I plan on keeping my rig for at least 30yrs so I dont want to deal with it again any time soon.
I really wanted a Hobart or a Lincoln. However, I also wanted one that could do gas MIG welding (in addition to flux core wire welding). And I wanted cheap.Im considering hiring a freelance welder to come patch the rust holes in the body... If I were to try it myself, can anyone recommend a "cheap" welder that would get the job done?
Take thousands of pics - literally multiple pics of the same item from different views, etc.!AustinCJer said:Suggestion time...
How did/do you keep track of what-goes-where as you are dissembling the Jeep?
Best advice for body mount bolt removal (to avoid breaking any...)
