Lol good idea. I know highway speeds will bring down my temps as well so you could be onto something.Damn!!! That's impressive!! Good job!!
You should run a tube to your center console and make a fridge, lol.
I ripped out my AC to do the onboard air, and most on here were like, "Nnnnnnooooo!!!!!" LolLol good idea. I know highway speeds will bring down my temps as well so you could be onto something.
Lol!!My BMW can't even get that low and the system is working "perfectly" according to BMW. Asked on forums and they are all saying about 30 degrees below ambient is as good as the system can do. American cars may not be as reliable but at least they know how to make an AC system that cools the occupants.
You need a better BMW dealership/mechanic. Temperature output needs to be in that range to pass BMW CPO inspection. I've owned 3 e46s and they all blew super cold. Just recharged my ZJ to get it back to that level of cooling.My BMW can't even get that low and the system is working "perfectly" according to BMW. Asked on forums and they are all saying about 30 degrees below ambient is as good as the system can do. American cars may not be as reliable but at least they know how to make an AC system that cools the occupants.
Many factory manuals have charts of specs and ranges and there is a good chance that there is documentation to support the 30* below ambient claim however most vehicles will perform better than that. In the early days of R134A that was definitely true that 30* below ambient was pretty dang good. The technology improved though. I know that the Acura RL that was built from 1995 or 6ish until 2004 was a cold mofo. It had a 2 stage condenser in it and those were real cold. R134 does not perform as well as R12 did. That is fact. Humidity really strains an AC system along with ambient temp and sun load. I am certain that you understand this. One of the things that is mind boggling about todays cars is how little of a volume of refrigerant it takes to charge one. Many cars are very close to 1LB of refrigerant. Maybe slightly more. Older stuff took probably twice the charge. A key to good operation is the condenser has to be able to turn the refrigerant from a gas back to a liquid and that liquid needs to be cooled enough that the compressor can pull it down to a low pressure. As a rule of thumb, you refrigerant pressure will coincide with its temperature. R12 cars were pretty dead on. If you hooked up a gauge to an R12 system that was fully charged and the car not running the gauge pressure would read just about dead nuts the same pressure as whatever ambient temp is. Low side pressures while running would also reflect evaporator temps pretty close. R134 follows the same principle pretty close but not as close as R12 did.My BMW can't even get that low and the system is working "perfectly" according to BMW. Asked on forums and they are all saying about 30 degrees below ambient is as good as the system can do. American cars may not be as reliable but at least they know how to make an AC system that cools the occupants.
Thank you Jay Lenoat least they know how to make an AC system that cools the occupants.
