Teraflex 231SS [$700]
10827 Views 29 Replies 29 Participants Last post by  Kaffa
Product Information
Price $700
Rating 4
Average Price $282.89
Manufacturer Teraflex
Recommended Yes: 29 / No: 0
Teraflex heavy duty short shaft kit
part # 004444401 231SS-slip yoke eliminator kit
21 - 30 of 30 Posts
Price $420
Rating 5
Pros Great instructions. Great quality
Cons None
Recommended yes
Comments: This was my first time intalling a SYE. Instructions made it very easy. Purchased with a CV. A great product that im sure will last. Make sure you have a QUALITY set of snap ring pliers! If your thinking about buying a SYE and CV do it. It makes everything smoother and no more vibrations!
See less See more
Price $420
Pros Great Price
Cons None
Recommended yes
Comments: I purchased this SYE with a Tatton drive shaft. I have nothing negative to say about this product. It's a great price for this nice setup.
See less See more
Price $370
Pros Reduces drive line angle
Vibration gone
Eliminated t-case drop kit
Cons expensive
difficult to zero the speedo
Recommended yes
Comments: Had my local 4x4 shop do the work (Four To Go), with cv style drive shaft with center pivot ball I really like the system...no more vibration, better angles and more clearance without the t-case drop...may have only needed the HD version (with a 4" lift) rather than the SS but might as well get a little more shaft for the money! I picked up over 9" of additiona ldrive shaft too. Speedo is way off...I may need the conversion box.
See less See more
Price $1
Pros Great product, have had no problems in the past 2 years i have had it.
Cons Only thing, i had to contact teraflex for a replacement output seal. I could not find it online or at my local shop. But they replied back within 24hours and i had the seal at my house within 3 days. Good service.
Recommended yes
Comments: It was free for me cuz, it was on my jeep when i bought it used. You can feel a vibration in my friends jeep without a sye kit, mine NO vibration. :)
See less See more
Price $350
Pros everything..soo far
Cons nothing....yet
Recommended yes
Comments: not real hard to instal.
only down fall. the super short uses a speedo ring. and you get a new speedo reader to read the ring...well it didnt plug into my main harness. soo you have to do a little electrical work. or not have a speedometer!
See less See more
Price $1
Pros Best there is
Cons none
Recommended yes
Comments: Best in my opinion
See less See more
Price $1
Pros Super-short
Cons none
Recommended yes
Comments: Helps to get a Chevy driveline in a YJ...
See less See more
Price $300
Pros Allows for a longer driveshaft
Cons Not as good as the JB conversions
Recommended yes
Comments: Seems to work out without any problems. I didn't install it myself, I bought a transfercase with the SYE and teralow already installed for $300
See less See more
Price $300
Pros Simple install, works flawlessly, and is obviously SuperShort.
Cons Instead of replacing a gear to correct speedo, you have to spend 200 on an electronic speedo "healer". But not a con for me because it is simple math to guestimate.
Recommended yes
Comments: Like mentioned, install was simple and smooth. Granted, I used directions from 4x4explor because the directions that come with can be more then a bit vague at times. I haven't had a single issue and it's been in for a month or two now.
See less See more
Price $240
Pros Works as expected.
Cons None yet.
Recommended yes
Comments: Not much to comment on here. It does what it's supposed to do.
See less See more
21 - 30 of 30 Posts
