Status
Not open for further replies.
1 - 17 of 17 Posts
Little Red Menace
EricsXJ and I decided to finally post up some links that could be used as a reference for a lot of the major question the board seems to have. PM me additional links that you think are necessary.
Special thanks to:
EricsXJ
GottaBeJeep
cfkingfish
lbsnowryder
Islandroaddie96
Roll Tide
XJ99
LOCKED UP
JVracer04
kapplera
sonicjay
xjfanatic
twisted_ed
fatwreck
cmotsvt
el_chupo_
Walton99
conrasm
nick_deno
zach1288
Andrew2516
Jeepin_XJ_101
00xj54
drew and not you
madrabbitt
XJ Xtreme
DefaZ
AZ Jeff
JBassXJ
Jeds Sr.
ben1.8t
sharpie1k
jeepkid8037
tozier9
CJ7-Tim
Blue-J
Steve88XJ
Kyle Deidrick
Atari.fan3000
TheRifleman
PESteele
Jmila1901
XJohnnyC
Cherokeegrrl
fourwheelerjeff
lost honda pro
mortalenema
dude_in_an_XJ
T4STE
Higgs98XJ
the_weirdo
89SAFARIXJ
HCI_Stang
XJ9635
Paraleyes
captain_ruggy
HERE WE GO:
Little Red Menace
Little Red Menace
Little Red Menace
**SUSPENSION MODS AND FIXES**
DIY DRIVE WAY ALIGNMENT
http://www.go.jeep-xj.info/HowtoAlignment.htm
HOW TO REMOVE REAR SWAY BAR
http://members.tripod.com/Jeep_n_John/swaybar.html
REDRILLING STOCK TRAC-BAR MOUNT AFTER LIFT
http://www.go.jeep-xj.info/HowtoTrackbar.htm
HOMEBREWED LONG ARMS
http://www.jeepforum.com/forum/showthread.php?t=248377
DEATH WOBBLE FIXES
www.kevinsoffroad.com/techarticles/deathwobble.html
http://www.yuccaman.com/jeep/dw.html
HOME BREWED BPE FRONT AND REAR
http://www.jeepforum.com/forum/showthread.php?t=91472
www.lunghd.com/Tech_Articles/Suspension_Steering_Axles_and_Brakes/Rear_BPEs.htm
REAR SHOCK MOUNT RELOCATION (higher mount more ground clearence)
http://www.go.jeep-xj.info/HowtoRearShockM.htm
REAR UPPER SHOCK MOUNT REPAIR/ OPTIONS (BPE's)
www.rocklizardfabrications.com/broken_shock_mounts.htm
http://www.jeepforum.com/forum/showthread.php?t=323809
SHOCK LENGTH GUIDE FOR DIFFERENT LIFTS SIZES (other tech too)
http://www.jeepforum.com/forum/showthread.php?t=751414
QUICK DISCONNECTS
http://jeep.off-road.com/jeep/article/articleDetail.jsp?id=257890
http://www.jksmfg.com/support.htm
DIY QUICK DISCONNECTS
http://www.off-road.com/jeep/cherokee/98/08_aug/disconnect/disconnect.html
http://www.cardomain.com/ride/325707/12
ADJUSTING BUMPSTOP LENGTH
www.rocklizardfabrications.com/Adjusting_Bumpstops.htm
HOMEBREWED TC DROP BRACKET
http://www.go.jeep-xj.info/HowtoTCdrop.htm
LCA and UCA LENGTHS FOR DIFFERENT LIFT SIZES
http://www.yuccaman.com/jeep/re_db.html
WJ CONTROL ARMS FOR LESS RUBBING UP TO 3-3.5" LIFT
http://www.madxj.com/MADXJ/technical/technicalfiles/BSlowerWJctrlArms/WJ_LCA.htm
Little Red Menace
**FRONT AND REAR AXLES // DRIVESHAFTS**
DOUBLE CARDAN REBUILD
http://www.pavementsucks.com/tech/doublecardan.php
http://www.jeepforum.com/forum/showthread.php?t=345170
http://www.stu-offroad.com/axle/driveshaft/driveshaft-5.htm
DIFF COVER INSTALL
http://www.jeepforum.com/forum/showthread.php?t=429732
PINION SEAL REPLACEMNT FOR D30 AND D35
http://www.jeepingsingles.net/tech/pinionseal.asp
STOCK JEEP AXLE GUIDE
http://www.tellico4x4.com/index.php/cPath/2880_76_2934
FRONT AND REAR AXLE GUIDE
http://www.yuccaman.com/jeep/gear1.html
http://memimage.cardomain.net/member_images/1/web/325000-325999/325707_182_full.jpg
http://www.xjjeeps.com/tech_reference.asp?section=2&ID=3
8.25 - http://www.jeepforum.com/wiki/index.php/Chrysler_8.25
d35 - http://www.jeepforum.com/wiki/index.php/Dana_35
GEAR RATIO CHART AND FORMULA FOR TIRE SIZES
http://www.superlift.com/library/gears.asp
FRONT D30 AXLE and STEERING
XJ FRONT LEAF CONVERSION
www.pirate4x4.com/tech/billavista/Leafspring_conversion/leafs.htm
ZJ TO XJ TIE ROD CONVERSION (couple of TJ articles, but XJ and TJ use same steering linkage)
http://www.jeephorizons.com/tech/tjtierod/
http://www.stu-offroad.com/steering/zjtie/tierod-1.htm
http://members.rennlist.com/gman/jeep/
TIE ROD END DUST BOOT REPLACEMENT (poly boots can be bought at most auto parts stores if you can't find factory replacements)
http://www.go.jeep-xj.info/HowtoTieRod.htm
STEERING STABILIZER REPLACEMENT
http://www.4x4xplor.com/steeringstabilizer.html
STEERING
STEERING STOP ADJUSTMENT (On a TJ, but same set up as the XJ knuckles)
http://www.4x4xplor.com/steerstop.html
DANA30 HOME_BREWED POSI_LOCK SYETEM AND VACUUM DIAGRAM
http://www.gljt.org/modules.php?name=Forums&file=viewtopic&t=10033
http://www.4x4wire.com/dodge/tech/solid_axle_cad/
http://www.driveev.com/jeepev/convpgs/4x4convert.php
FRONT HUB REPLACEMENT
www.off-road.com/jeep/cherokee/2001/02_feb/bearing/index.html
BALL JOINT REPLACEMENT
http://www.madxj.com/MADXJ/technical/technicalfiles/ARadjustableBallJoints/adjustableballjoints.htm
D30 PINION SEAL
http://www.madxj.com/MADXJ/technical/technicalfiles/SRpinionSeals/PinionSeals.htm
D30 AXLE SEALS INSTALL
http://www.delta4x4club.com/TECH/JEEP/TUBESEALS.php
FRONT HUB CONVERSION
http://www.delta4x4club.com/TECH/JEEP/HUBS.php
SWAPPING 1 PIECE TJ AXLES INTO A VAC DISCO D30
http://www.stu-offroad.com/axle/yjd30convert/yjconvert-1.htm
XJ DANA30 / 297-X UJOINT UPGRADE/ UJOINT REBUILD
www.madxj.com/MADXJ/technical/technicalfiles/ARD30shafts297andSeals/D30shafts297andSeals.htm
http://www.4x4wire.com/tech/axle/ujoint/
http://www.jeepin.com/features/ujoint/index.asp
http://www.delta4x4club.com/TECH/UNIVERSAL/UJOINTS.php
LOCK RITE LOCKER INSTALL (TALL GEARS) WITH CARRIER REMOVAL STEPS
http://www.jeepaholics.com/tech/lrhubs/default.htm
http://www.4x4wire.com/jeep/tech/axle/lr00a/
REAR AXLE
XJ DANA44 AXLE SWAP
www.pirate4x4.com/tech/billavista/D44_buildup/D44.htm
RING AND PINION INSTALL (GEARS) ON A CHRY-CO 8.25 AXLE
http://www.jeepforum.com/forum/showthread.php?t=109859
http://www.rockfrogs.org/phpBB2/viewtopic.php?p=8170&sid=3952ea190959f1a13b9ca48330e3c63b
AXLE PIC CHART FOR COMMON AXLES
PICS OF A D35 AND A CHRYSLER 8.25 REAR AXLES
http://www.jeepforum.com/forum/showthread.php?t=88078
FORD 8.8 REAR AXLE SWAP INFO
http://members.cox.net/rough-riders/tech_page/ford8.8/ford8_8.html
http://www.bc4x4.com/tech/2003/xj88/
http://www.4x4wire.com/jeep/tech/axle/ford8_8/
http://xjfanatic.com/ford88.php
http://www.jedi.com/obiwan/jeep/ford88.html
LARGE TECH AND FAQ ON THE 8.8
http://www.jeepsunlimited.com/forums/showthread.php?t=674123
Little Red Menace
**RECOVERY AND PROTECTION**
SIMPLE TO THE POINT DIY FRONT RECOVERY BUMPER
http://jeep_n_john.tripod.com/bumperpage1.htm
CRUDE DIY TOWHOOK BRACKET SCHEMATIC
http://www.bc4x4.com/tech/2004/xjhook/
TOW HOOK INSTALLATION
www.off-road.com/jeep/cherokee/99/11_nov/cust4x4hooks/cust4x4hooks.html
INSTALLING PRE 96 TOW HOOK BRACKETS ON A 97+
http://www.jeepforum.com/forum/showthread.php?t=485570
SKIDROW TRANSFER CASE SKID
http://www.delta4x4club.com/TECH/JEEP/TCASESKID.php
TOMKEN TRANS SKID
http://www.ericsxj.com/tomken.htm
MOPAR GAS TANK SKID / RECEIVER HITCH
BUMPER INSTALLATION (FRONT)
REAR HIDDEN HITCH INSTALL
http://www.cardomain.com/ride/325707/13
TRAILER HITCH WIRING INSTALL
http://www.jeepin.com/features/trailerwiring/index.asp
Little Red Menace
**TRANSMISSION AND TRANSFER CASE**
General AX5 INFO
http://www.novak-adapt.com/knowledge/ax5.htm
General AX15 INFO
http://www.novak-adapt.com/knowledge/ax15.htm
General AW4 INFO
http://www.novak-adapt.com/knowledge/aw4.htm
http://jeepforum.com/forum/showthread.php?t=273048
GENERAL NP231 INFO
http://www.novak-adapt.com/knowledge/np231.htm
GENERAL NP207 INFO
SWAPPING IN A MANUAL FOR AN AUTO
http://www.jeepforum.com/forum/showthread.php?t=258497
B&M TRANS TEMP GAUGE INSTALL
http://jeepin.com/features/tranny_temp_gauge/index.asp
http://4x4trailhunters.com/tech/article.php?id=12
B&M AUX TRANS COOLER
http://www.cardomain.com/ride/325707/11
http://www.jeepin.com/features/trannycooler/index.asp
TRANS GEAR RATIOS
AX15- http://www.off-road.com/jeep/tech/trans/ax15.html
AX5- http://www.off-road.com/jeep/tech/trans/ax5.html
BA10/5- http://www.off-road.com/jeep/tech/trans/ba10.html
TF904/909- http://www.off-road.com/jeep/tech/trans/tf904.html
AW4- under best auto trans http://www.off-road.com/jeep/cherokee/xjtech/jeepspeedfaq/
NUETRAL SAFETY SWITCH REBUILD
http://jeepin.com/features/nss
http://jp.automotive.com/93239/154-0805-1987-2001-jeep-cherokee-neutral-safety-switch/index.html
http://www.boyandjeep.com/tech-articles/aw4-neutral-start-switch-rebuild
NUETRAL SAFETY SWITCH REBUILD AND SCHEMATICS
http://www.cherokee-jeep.com/1-2swremov.htm
AW4 TRANSMISSION OVERRIDE SWITCH
http://www.go.jeep-xj.info/HowtoAutoSwitch.htm
http://jeepforum.com/forum/showthread.php?t=234510
http://members.cox.net/steve88xj/aw4/
http://www.jeepforum.com/forum/showthread.php?t=234510
SPEEDO GEAR SWAP FOR RECALIBRATING SPEEDO (BIGGER TIRES)
http://jeepin.com/features/speedogear/index.asp
www.off-road.com/jeep/cherokee/98/07_jul/speedo/speedo.html (note: chart #'s in this article are wrong.)
GREASING THE OUTPUT SHAFT/SLIP YOKE
http://www.jeepforum.com/forum/showthread.php?t=357569
REPLACING THE REAR OUTPUT SEAL (SLIP YOKE HOUSING)
http://www.go.jeep-xj.info/HowtoTCseal.htm
FIX FOR A NP242 STUCK IN 4PART TIME
http://www.jeepforum.com/forum/showthread.php?t=427233
NP231 PARTAIL OVERHAUL
http://4x4trailhunters.com/tech/article.php?id=20
NP242 PARTAIL OVERHAUL
http://www.mallcrawlin.com/forum/showthread.php?t=8549
NP241OR RUBICON TRANSFER CASE SWAP INFO
http://www.jeepforum.com/forum/showthread.php?p=3056557&posted=1#post3056557
http://www.jbconversions.com/pages/reviews/showpage.php?m=4wor&i=2004.07_n2&p=1
NP231 TO NP242 SWAP
http://www.weatherlover1.com/jeep/242.htm
DIY WIDE CHAIN NP231
http://www.madxj.com/MADXJ/technical/technicalfiles/JAtCaseUpgrade/tCaseUpgrade.htm
TRANSFER CASE DROP INSTALL
http://www.jeepforum.com/forum/showthread.php?t=405578
The Official SYE (Slip Yoke Eliminator) Thread
http://www.jeepforum.com/forum/showthread.php?t=426483
DOWN AND DIRTY HOMEMADE SYE FOR ODD TRANSFER CASES OR CHEAP SOBs
http://www.naxja.org/forum/showthread.php?t=80289
**SYE (Slip Yoke Eliminator) NP231 TC (XJ and YJ/TJ use the same methods for install)**
ADDITIONAL AA/PORC SYE INFO
http://www.jeepforum.com/forum/showthread.php?t=212704
http://www.yuccaman.com/jeep/****_sye.html (you have to copy, paste, and add porc manually in place of the ****)
ADDITIONAL RE Hack-N-Tap/FRONT DS COMBO
http://www.jeepforum.com/forum/showthread.php?t=186995&highlight=adapter+hack%2A
VIDEO OF A AA OR **** TYPE SYE INSTALL
http://www.crgrissom.com/jeep/SYE.wmv
AA- http://www.4x4wire.com/jeep/reviews/aasye99/
http://www.4x4xplor.com/SYE-CV.html
RE 88-95- http://www.dorianjepsen.com/wrangler/syekit/index.php
http://www.dpgoffroad.com/tech/rubiconsye.htm
RE 96-01- http://www.yuccaman.com/jeep/sye.html
www.off-road.com/jeep/cherokee/98/03_mar/RE_SYE/slip-yoke.html
Tom Woods- http://www.polytropia.com/cherokee/sye.html
JB- http://www.rockcrawler.com/techreports/JB_Wood_crosstrainer/index.asp
http://www.jpmagazine.com/howto/29623/
http://7slotgrille.com/tech/sye2/
DIY Hack-n-tap STYLE SYE FOR NP231
SYE (Slip Yoke Eliminator) NP242 TC
RE- http://www.polytropia.com/cherokee/sye.html
http://www.angelfire.com/nc3/84jeepxj/sye.html
JB CONVERSIONS "SHORTY" SYE
http://www.jeepin.com/features/supershorty/index.asp
DATABASE OF DIFFERENT MAKERS CV DRIVESHAFTS FOR CHEAP SYE
ADDITIONAL INFO ON STOCK ADAPTERS FOR HACK-N-TAP/STOCK DS COMBO
http://www.jeepforum.com/forum/showpost.php?p=1377046&postcount=2
Little Red Menace
Discussion Starter · #8 ·
Little Red Menace
Discussion Starter · #9 ·
Little Red Menace
**BODY MODS**
FACTORY PAINT CODE LOACTION AND HOW TO READ IT
Find Your Paint Code Location
HOMEMADE DIY GUTTER MOUNTS FOR A RACK
Homebrewed Gutter-Mount Roof Rack
PUTTING 97+ FRONT CLIP ON A OLDER XJ
97+ Panel swap
STUCK HATCH FIX
Fixed the hatch today...
HOMEBREWED REMOVALABLE DOOR
myXJ.Net
97+ http://jeepforum.com/forum/showthread.php?t=408138
TRIMMING FENDERS
www.madxj.com/MADXJ/technical/technicalfiles/JAfenderTrimming/FrontFenderTrim.htm
(Front Fender Trimming)
www.madxj.com/MADXJ/technical/technicalfiles/SRrearFenders/rearfender.htm
(Rear Fender Chop)
Jeepin.com: "Stage-one" XJ fender trimming
Fender Trimming
DELTA 4X4 CLUB TECHNICAL DEPARTMENT - JEEP CHEROKEE XJ FENDER CUTTING AND TRIMMING
Write Up: Cutting & Folding Rear Fenders (rear fender cut and fold)
http://www.jeepforum.com/forum/f11/write-up-inner-fender-trimming-clearance-big-tires-955688/
CUSTOM TUBE FENDERS
Tube flare write up. - NAXJA Forums -::- North American XJ Association
CUTTING REAR LOWER QUARTERS
Paraleyes- http://www.jeepforum.com/forum/f11/cut-fold-rear-lower-quarter-panels-right-way-1007865/#post9237914
http://www.naxja.org/forum/showthrea...lower+quarters
POOL NOODLES TO FILL GAPS
TJ FLARE INSTALL
XJ TJ Flare Install
korda's XJ | mods | TJ flares
http://www.cardomain.com/ride/588437/10
TJ flares and Paint finally done! - NAXJA Forums -::- North American XJ Association
Trimming rear Fenders & Installing TJ flares (Lotta pics)
FENDER FLARE RELOCATING
www.madxj.com/MADXJ/technical/technicalfiles/TPfenderFlares/FenderFlares.htm
Yucca-Man: 53guy's Rear Fender Trim Write-up, retaining the stock flare (Best I've seen!)
INSTALLING NEWER (97+) DOOR SEALS ON OLDER XJ
www.madxj.com/MADXJ/technical/technicalfiles/ARdoorSeals/DoorSeals.htm
HOOD VENTS
Tech article - Hood Vents
DELTA 4X4 CLUB TECHNICAL DEPARTMENT - LEBARON HOOD VENTS
Extreme Duty Replacement Rocker Panels
3"x4" Custom rocker panel replacement using box steel to withstand any trail abuse there is.
www.madxj.com/MADXJ/technical/technicalfiles/SRrockerPanels/RockerPanels.htm
Extreme Custom Heavy Duty Rocker Panels
Completely custom-made hard core custom rocker panel replacement. Possibly the most complicated/sophisticated way of building weld-in rocker panel replacements.
www.madxj.com/MADXJ/technical/technicalfiles/JArockRails/RockRails.htm
Serious High-Clearance Rocker Panel Replacement
2"x6" Custom rocker panel replacement with ultimate ground clearance gains, requiring the doors to be shortened! Rockers setup as air tanks also.
Heavy hacking ahead!
www.madxj.com/MADXJ/technical/technicalfiles/ARrockerPanels/RockerPanels.htm
Replacing Rear Quarter Window
http://www.jeepforum.com/forum/f177/how-install-rear-cargo-window-jeep-cherokee-xj-zj-1143392/
Little Red Menace
**INTERIOR AND ELECTRICAL**
DIY SECURITY CONSOLE WITH STOCK PARTS
http://jeepforum.com/forum/showthread.php?t=394307
GRAND CHEROKEE SEATS FRONT AND REAR IN A XJ
http://www.jeepforum.com/forum/showthread.php?t=353084
http://www.jeepforum.com/forum/showthread.php?t=752202
HOW TO TIGHTEN UP A LOOSE TILT STEERING WHEEL COLUMN
http://www.chevyasylum.com/column/tiltcol.html
HOW TO REPLACE KEY CYLINDER ON 88
http://www.naxja.org/forum/showthread.php?t=939364&highlight=ignition+lock+removal
HOW TO REPLACE KEY CYLINDER ON 96
http://www.sparkys-answers.com/2009/04/1996-jeep-cherokee-blower-inop.html
KEY STUCK IN CYLINDER
http://www.jeepforum.com/forum/showthread.php?t=530673
REPLACING THE DOOR LOCK ACTUATOR ON A 97+
http://www.links4jeeps.com/writeups/lock_actuator/
REPLACING THE TURN SIGNAL MULTI_SWITCH ON A 97+
http://www.jeepforum.com/forum/showthread.php?t=620147&highlight=turn+signal
97+ WINDOW NOT WORKING EXCEPT DRVS SIDE
http://www.jeepforum.com/forum/showthread.php?t=288655&highlight=door+locks
INSTALLING 97+ WEATHER STRIPPING ON A PRE97
http://www.madxj.com/MADXJ/technical/technicalfiles/ARdoorSeals/DoorSeals.htm
COMPASS AND CLOCK CALIBRATION INFO
http://www.jeepforum.com/forum/showthread.php?t=313788
DIY IGN KILL SWITCH
http://autospeed.drive.com.au/cms/article.html?&A=0059
BEDLINING THE FLOORBOARD
http://jeepforum.com/forum/showthread.php?t=239647&highlight=bedlined+floor%2A
http://jeepforum.com/forum/showthread.php?t=171378&highlight=bedlined+floor*
HEADLINER REPARE INSTALL
http://www.lunghd.com/Tech_Articles/Interior/Headliner.htm
http://www.wlsheadliners.com/tutorials/cherokee/
http://www.4x4xplor.com/headliner.html
WALMART OFFROAD LIGHT COVER MOD
http://www.jeepforum.com/forum/showthread.php?t=355895&page=3
WALMART OVERHEAD LIGHTS MOD
http://www.jeepforum.com/forum/showthread.php?t=63531&highlight=walmart+light
http://www.jeepforum.com/forum/showthread.php?t=137964&highlight=walmart+light
http://www.jeepforum.com/forum/showthread.php?t=64092&highlight=walmart+light
http://www.jeepforum.com/forum/showthread.php?t=96255&highlight=walmart+light
HEADLIGHT UPGRADES
http://www.jeepforum.com/forum/showpost.php?p=2145691&postcount=15
http://www.go.jeep-xj.info/HowtoHeadlightLoom.htm
ONE OF THE BEST HD HEADLIGHT HARNESS WRITE UPS I HAVE EVER READ
http://fitchva.com/jeep/?p=57
LED TAILIGHT CONVERSION
http://www.driveev.com/jeepev/convpgs/ledlighting.php
LED INTERIOR/CLUSTER CONVERSION
http://www.jeepforum.com/forum/showthread.php?t=486998
CLUSTER CONVERSION
http://www.jeepforum.com/forum/showthread.php?t=752630
INTERIOR STORAGE DECK
http://www.ericsxj.com/storage.htm
http://www.jeepforum.com/forum/showthread.php?t=197251
INTERIOR STORAGE DECK (With the add-on for leveling out cargo with seat down)
http://www.yuccaman.com/jeep/storage.html
97+ QUARTZ CLOCK INSTALL IN A PRE 97XJ
http://www.jeepforum.com/forum/showthread.php?t=64514
http://www.go.jeep-xj.info/HowtoDashClock.htm
CB RADIO
SPEAKER UPGRADES / SUB ENCLOSURES
http://www.jeepforum.com/forum/showthread.php?t=97186
LED BACKLIGHTING FOR GAUGE PANEL
http://www.jeepforum.com/forum/showthread.php?t=109945
GAUGE SWAP
http://www.jeepin.com/features/gaugeswap/index.asp (88-90 to 91-95 cluster swap)
ON BOARD AIR INSTALLATION
http://www.rocklizardfabrications.com/power_tank.htm
http://www.ericsxj.com/oba.htm
UPGRADING CHARGING SYSTEMS (slow starts and better charging)
http://www.bc4x4.com/tech/2004/jeepalt/
UPGRADING YOUR ELECTRICAL SYSTEM TO SUPPORT HIGH-AMPERAGE ACCESSORIES
http://jeep.off-road.com/jeep/article/articleDetail.jsp?id=277034
BUILD YOUR OWN HD BATTERY CABLES AND GROUND STRAP
http://www.geocities.com/JeepI6Power/electric.html
http://www.jeepforum.com/forum/showthread.php?t=444922
http://www.jeepforum.com/forum/showthread.php?t=445428
http://www.jeepforum.com/forum/showthread.php?t=444082
UPGRADING A 87-90 WITH A 136AMP ALTENATOR
http://www.jeepforum.com/forum/showthread.php?t=338597
http://www.naxja.org/forum/showthread.php?t=930069&highlight=external+regulator
DUAL BATTERY
www.pirate4x4.com/tech/billavista/dual_battery/my_dual_battery_setup.htm
www.4wdandsportutility.com/tech/03054wd_batteries/
http://www.madxj.com/MADXJ/technical/technicalfiles/ARbattRelocation/BattRelocation.htm
http://www.hellroaring.com/4wheel.htm
http://www.wranglernw.com/pc-6370-79...1987-2001.aspx
HVAC BLOWER FIX (if motor speed selector not working)
www.geocities.com/chmwatson/FAQs/Jeep/HVAC-fuselink_fix.html
HVAC VACUUM DIAGRAM (FOR A 92)
http://autorepair.about.com/library/images/bl312a-lib.htm
HVAC HEATER BLOWER MOTOR REPLACEMENT ?-96
http://www.lunghd.com/Tech_Articles/Electrical/Heater_Blower_Motor.htm
HVAC HEATER BLOWER MOTOR REPLACEMENT 97-01
http://autorepair.about.com/library/a/1i/bl793i.htm
http://www.jeepforum.com/forum/showthread.php?t=367612
HVAC HEATER CORE REPLACEMENT
http://autorepair.about.com/library/a/1h/bl566h.htm
http://www.naxja.org/forum/showthre...ghlight=heater+core+replacement#post243641386
WIRING SCHEMATICS FOR 1984 - 1998 XJ AND MJ
http://www.autozone.com/servlet/UiB..._us/0900823d/80/15/3e/8f/0900823d80153e8f.jsp
FUSE BLOCK DIAGRAM FOR '00 XJ's
http://www.jeepforum.com/forum/showthread.php?t=33820
Little Red Menace
Discussion Starter · #13 ·
Little Red Menace
Discussion Starter · #14 ·
**ENGINE MAINT, PERFORMANCE, AND UPGRADES**
DYNOMAX CAT BACK INSTALL
http://www.cardomain.com/ride/325707/10
INSTALLING A FLOWMASTER TO STOCK EXHAUST
http://www.jeepforum.com/forum/showthread.php?p=3918726&posted=1#post3918726
HEADER OPTIONS FOR THE 00-01 4.0L
http://www.jeepforum.com/forum/showthread.php?t=502290
V8 SWAP INFO. LOTS OF INFO ON WHAT WILL WORK AND HOW TO FIT IT
http://www.novak-adapt.com/knowledge/xj_swap.htm
2.8L to 3.4L ENGINE SWAP
http://www.lunghd.com/Tech_Articles/Project_XJ/Project_XJ.htm
POSSIBLE HIGH IDLE SOLUTION
COMMON MISFIRE CONDITION ON 00-01 (INJECTOR 3)
http://www.jeepforum.com/forum/showthread.php?t=72181
CPS REMOVAL
http://www.jeepforum.com/forum/showthread.php?t=197260
http://www.yuccaman.com/jeep/cps.html
CHECKING THE COIL AND CPS TESTING PROCEDURES
http://autorepair.about.com/library/faqs/bl077g.htm
CHECKING THE CAM POSTION SENSOR AND CRANK POSTION SENSOR (aka CPS)
DIY OBA (On Board Air) USING STOCK AC COMPRESSOR
http://www.jeepforum.com/forum/showthread.php?t=194132
DIY ADJUSTABLE MAP SENSOR
http://www.jeepbarracks.com/modules.php?name=News&file=article&sid=18
TB CLEANING THREADS/Link
http://www.off-road.com/jeep/cherok...ngine/tbody.htm
http://www.jeepforum.com/forum/showthread.php?t=143804
http://www.jeepforum.com/forum/showthread.php?t=154516
NON-HO TO HO SWAP, QUICK OVERVIEW
http://www.off-road.com/jeep/cherokee/99/09_sept/engswap/engswap.html
INSTALLING A 99+ INTAKE ON A 91-98 HO HEAD
http://www.jeepforum.com/forum/showthread.php?t=215685
CHECKING AND ADJUSTING THE TPS ON A 87-90 4.0L
http://autorepair.about.com/library/faqs/bl232i.htm
READING THE OBDII DIAGNOSTIC CODES
http://www.getahelmet.com/jeeps/tech/codes/
http://www.allpar.com/fix/computer-codes.html
READING OBDI DIAGNOSTIC CODES
http://go.jeep-xj.info/HowtoECUcodes.htm
OIL IN AIR FILTER (BLOW BY) FIXES
www.off-road.com/jeep/cherokee/xjtech/engine/40ltr/blowby.htm
www.off-road.com/jeep/cherokee/98/04_apr/valvecover/cover.html
www.madxj.com/MADXJ/technical/technicalfiles/JAvalveCover/ValveCover.htm
http://www.yuccaman.com/jeep/filter.html
INSTALLING A EXTERNAL IN-LINE FUEL PUMP
http://www.delta4x4club.com/TECH/JEEP/SWAMPYBYPASS.php
REPLACING FUEL FILTER ON A 97+
http://www.jeepforum.com/forum/showthread.php?t=138580
OIL PRESSURE SENDING UNIT TROUBLESHOOTING
CONVERTING TO LARGER OIL FILTER
www.madxj.com/MADXJ/technical/technicalfiles/ARoilFilterConversion/OilFilterConversion.htm
FUEL INJECTOR O-RING REPLACEMENT
www.off-road.com/jeep/cherokee/xjtech/engine/oring.html
CHANGING THE OIL ADAPTER O-RINGS
http://www.cardomain.com/ride/325707/3 (Cardomain is messed up. Go To page3 for writeup)
http://www.lunghd.com/Tech_Articles/Engine/Oil_Filter_Mount_O-Rings.htm
www.madxj.com/MADXJ/technical/technicalfiles/ARoilFilterConversion/OilFilterConversion.htm (covers removal and
install of Oil FIlter Adapter Housing).
MOTOR MOUNT REPLACMENT
http://www.jpmagazine.com/howto/31818/
www.off-road.com/jeep/cherokee/xjtech/engine/engmounts/
www.off-road.com/jeep/cherokee/2001/01_jan/EngineMounts2/mount.html
http://jeepin.com/features/motormounts/index.asp
REAR MAIN SEAL REPLACEMENT
http://jeepin.com/features/rearmain/index.asp
BORING A HO (91+ 4.0L) THROTTLE BODY OUT TO 60mm
http://go.jeep-xj.info/HowtoTBboring.htm
http://www.cardomain.com/memberpage/325707/2
ARB SNORKLE INSTALL
http://www.delta4x4club.com/TECH/JEEP/SNORKEL.php
HOMEBREWED SNORKLE/ DEEP WATER INTAKES
www.pirate4x4.com/tech/billavista/snorkel/snorkel.htm
www.madxj.com/MADXJ/technical/technicalfiles/JAairIntake/AirIntake.htm
www.madxj.com/MADXJ/technical/technicalfiles/JJcustomSnorkle/CustomSnorkle.htm
REMOVING STOCK AIR BOX SILENCER/VENTURI
www.go.jeep-xj.info/HowtoSilencer.htm
OPEN AIR (CONE FILTER) INTAKES
http://www.patricksnorton.com/cherokee/tech/afilter.php
http://www.cardomain.com/ride/325707/7
MUSTANG CONE STYLE AIR BOX CONVERSION
http://www.jeepforum.com/forum/showthread.php?t=462724
STROKER ARTICLES FOR THE 4.0L
http://www.angelfire.com/my/fan/stroker.html
www.madxj.com/MADXJ/technical/technicalfiles/DMstrokerStory/StrokerSummary.htm
http://www.bc4x4.com/tech/bryce/stroker/stroker.cfm
NUTTER BYPASS AND VARIOUS OTHER INFO ON CARB'D APPLICATIONS
http://www.m1911.org/cherokee_mods.htm
Little Red Menace
Discussion Starter · #15 ·
Little Red Menace
Discussion Starter · #16 ·
TSBs for 84-01 2wd and 4wd 4.0L
Here is the link: http://www.alldata.com/recalls/index.html but below is the quick reference short cut. If time allows I will add the 4cyl to the listings
Realize these are not dirctions how to fix, unless you buy the service, but more like known issues with the given years. Use this as a refernce to search for answers to issues.
1984 Jeep Truck Cherokee (No listing for 2wd or 4wd, just one title.)
http://www.alldata.com/TSB/04/840410cL.html
1985 Jeep Truck Cherokee 2WD
http://www.alldata.com/TSB/04/850416cL.html
1985 Jeep Truck Cherokee 4WD
http://www.alldata.com/TSB/04/850417cL.html
1986 Jeep Truck Cherokee 2WD
http://www.alldata.com/TSB/04/860416cL.html
1986 Jeep Truck Cherokee 4WD
http://www.alldata.com/TSB/04/860417cL.html
1987 Jeep Truck Cherokee 2WD
http://www.alldata.com/TSB/04/870416cN.html
1987 Jeep Truck Cherokee 4WD
http://www.alldata.com/TSB/04/870417cN.html
1988 Jeep Truck Cherokee 2WD
http://www.alldata.com/TSB/04/880416cN.html
1988 Jeep Truck Cherokee 4WD
http://www.alldata.com/TSB/04/880417cN.html
1989 Jeep Truck Cherokee 2WD
http://www.alldata.com/TSB/04/890416d4.html
1989 Jeep Truck Cherokee 4WD
http://www.alldata.com/TSB/04/890417d4.html
1990 Jeep Truck Cherokee 2WD
http://www.alldata.com/TSB/04/900416d4.html
1990 Jeep Truck Cherokee 4WD
http://www.alldata.com/TSB/04/900417d4.html
1991 Jeep Truck Cherokee 2WD
http://www.alldata.com/TSB/04/910416d9.html
1991 Jeep Truck Cherokee 4WD
http://www.alldata.com/TSB/04/910417d9.html
1992 Jeep Truck Cherokee 2WD
http://www.alldata.com/TSB/04/920416d9.html
1992 Jeep Truck Cherokee 4WD
http://www.alldata.com/TSB/04/920417d9.html
1993 Jeep Truck Cherokee 2WD
http://www.alldata.com/TSB/04/930416d9.html
1993 Jeep Truck Cherokee 4WD
http://www.alldata.com/TSB/04/930417d9.html
1994 Jeep Truck Cherokee 2WD
http://www.alldata.com/TSB/04/940416d9.html
1994 Jeep Truck Cherokee 4WD
http://www.alldata.com/TSB/04/940417d9.html
1995 Jeep Truck Cherokee 2WD
http://www.alldata.com/TSB/04/950416d9.html
1995 Jeep Truck Cherokee 4WD
http://www.alldata.com/TSB/04/950417d9.html
1996 Jeep Truck Cherokee 2WD
http://www.alldata.com/TSB/04/960416d9.html
1996 Jeep Truck Cherokee 4WD
http://www.alldata.com/TSB/04/960417d9.html
1997 Jeep Truck Cherokee 2WD
http://www.alldata.com/TSB/04/970416d2.html
1997 Jeep Truck Cherokee 4WD
http://www.alldata.com/TSB/04/970417d2.html
1998 Jeep Truck Cherokee 2WD
http://www.alldata.com/TSB/04/980416d2.html
1998 Jeep Truck Cherokee 4WD
http://www.alldata.com/TSB/04/980417d2.html
1999 Jeep Truck Cherokee 2WD
http://www.alldata.com/TSB/04/990416d2.html
1999 Jeep Truck Cherokee 4WD
http://www.alldata.com/TSB/04/990417d2.html
2000 Jeep Truck Cherokee 2WD
http://www.alldata.com/TSB/04/000416d2.html
2000 Jeep Truck Cherokee 4WD
http://www.alldata.com/TSB/04/000417d2.html
2001 Jeep Truck Cherokee 2WD
http://www.alldata.com/TSB/04/010432d2.html
2001 Jeep Truck Cherokee 4WD
http://www.alldata.com/TSB/04/010434d2.html
Youngin'
1 - 17 of 17 Posts
Status
