Hello everyone, first post here (I have a '93 Bronco that I have posted about on BroncoZone). My son has been playing bumper cars with my 2000 XJ. The last event involved a jumped curb that punched a 3" hole in the tire, damaged the aluminum rim and the lower swing arm mount on the right side (the flange on the axle now has an "N" shape to it, body shop said not repairable). I have acquired a HP Dana off a '98 from the salvage yard. Asking for some opinions/advice. Gotta love the tree huggers, the salvage yard (at least here in VA) drills the bottom of the diff cover to drain the fluid so it doesn't leak into the dirt; 1st question, any recommendations on a replacement cover? Stock steel, chrome, aluminum, with drain plug, w/o, recommended manufacturers? :dunno: I'm thinking stock w/red paint... too generic? I've replaced the front fenders and the grill, going with an Army standard camo paint job w/Rustoleum flat camo, so far I have base green on the fenders, grill and hood, the rest is burgundy =:-o
I've been cleaning the axle in my driveway. There is a significant amount of gunk on the right side, mostly on the upper side of the lower arm where ball joint mounts, wondering if there may be a bad axle seal? The other side not nearly as bad. The whole axle was very greasy, so donor vehicle must have had bad engine seals anyway. I want to replace the axle seals and bearings, is that possible without removing the gears? My first foray into the realm of axle rebuilds. :thumbsup:
I don't have a good bench to work on, so my plan is to clean, paint, then install, which will provide the holding power to get the axle nuts off. Then I can disassemble the steering knuckles. The U-joints look good, I'm thinking the ball joints may be good as well, maybe even the hubs. Wondering if I should just replace while I have it opened up, or drive with what's there first and see how they perform?
Any thoughts and recommendations will be greatly appreciated, thanks!
