All the air bag does is raise the spring rate. More air = more spring rate.
It DOES NOT adapt unless you change the pressure.
I worked in medium truck for a while and they use airbags on trailers and rear axles, or at least they did when I was around them. Not two springs.
Why not just put the right spring in it and be done?
Thanks Craig.
Are there ever "Right" springs
when the parameters change please Craig?
Briefly: -
Highway touch release valve button
- lower pressure & ride height.
Off road, touch the pump button
- raise pressure 1/2 way & ride height 1/2 way
Really rough stuff, touch pump button
- Raise pressure all the way, ditto ride height.
On the way back,
thanks to reduced quantities of grub, booze, etc
lower pressures.
For really cool, air bag the front too.
Didn't the men using your trailers
change pressure in their airbags
to suit the parameters applying at the time?
