1 - 20 of 26 Posts
Thanks Jeep!
Just got this from Rocky Road..
Rocky Road Outfitters mentioned you in a comment.Rocky Road Outfitters wrote: "Stephen... Long story short, it is not possible to lift the new Cherokee.
Long story long, the front end does not have alignment adjustability. The only way to align the front is to loosen and slightly shift the "cradle" which doesn't provide enough adjustment to lift the vehicle. In case you might think, "Just build a new lower control arm". YOu could, but to change the lower control arm, you would have to remove the front 'clip'. This is an aluminum sub-frame which supports the front of the engine, radiator, and everything in front of the front axles. So to remove that control arm would probably be a thousand $ mechanic job and beyond the skills of most DIY'ers.
Therefore, we had to admit defeat and will not be producing a suspension lift for this Jeep. Really sucks. We're disappointed
It's really not surprising at all. I wouldn't be lifting a WKII either. If you want to do lifts stick to the old school jeeps with live front axles, like a TJ, XJ ZJ or WJ.
I was just hoping for a 2-3" lift, nothing too big, but wanted a quality lift to give a bit more flex and run 33"s
I just find it odd that Jeep chose to eliminate by "Design" any 3rd party products. That used to be the great thing about Jeep you had Choices!
That being said I may have gone up to a GC if I ever in a million years thought Jeep would design themselves into a box sort of speaking.
yeah seriously! I would kinda like to see if the desert runners would be able to make flared wheel panels. Would not get the flex that way, but would get more clearance
With the GC unless you get the factory quadralift you are not doing lifts on that either. Look at how these vehicles are designed, doing mods is basically impractical. You can fit a little taller tires and that's it. Just like no one does lifts on competing vehicles like a RAV4, Honda CRV, Subaru Forester, etc. For true lift-able Jeeps you have to go back in time. You can lift a WK (2005 to 2010) but its more complex because of the IFS and CV axle joint angles.
im actually not surprised you cant lift the new KL. personally i think the trailhawk looks aggressive enough on a set of 31s and with the drivetrain i think it will be somewhat capable with the proper armor. just sucks that jeep engineered it to be "unliftable", but these things are bound to happen as more and more vehicles go IFS and drop the SFA. but think of it this way, for the guys that always lift stuff and always get the itch- they know theyre limited so the urge is nipped in the but, so you have to focus on other things.
given the IFS of the WK, i find it crazy how close of an eye you need to keep on your CV angles and lift heights- anything over 23" on just springs youre SOL. it is complex to lift an IFS but it can be done if you have the sheckles to do so... $1400+ for a SL to get 4" on a WK no including labor and whatever else. :thumbdown:
Honestly I would have one of each; a newer street Jeep for winter driving and boat towing and an older TJ/XJ/ZJ lifted for off road and beach running. BTW the low resale value of older Grands makes them great deals to pick up used and modify.
ive honestly been kicking the idea of going back to a WJ and unloading the WK. but with a bun in the oven, 4drs some leather and creature comforts will make things alot easier.
down the road, ill be replacing the WK with a LJR once i can ditch the carseat :thumbsup:
It really does suck that you can lift one of these. Their not really my cup of tea but I think a KL with a lift and some 31's of so squeezed under it would look pretty cool and be pretty capable too.
Since it's really a front wheel drive European car platform, Fiat already built inthe max lift during the KL design. Read that it will take an entirely new subframe up front ad some kind of blocks in rear. Most likely mod will be to cut the body to clear larger tires.
Biggest bummer is that it defaults to FWD off road, the rears only kick in if the system detects front wheel slippage. Means that in soft stuff it will start to dig a hole in front.
Rocky road actually makes spacer lifts for the wk2. One or 2 inches but better than nothing.
They can do that because Jeep built the suspension Geometry to accommodate the QL system. So you can take a non-QL WK2 up... a little.
So you can't align the front end anymore? So if your tires are wearing odd you just have to live with it now? What?
Correct. The KL Trailhawk is already "lifted" 1" by the factory, there's no "easy" lift modification left in the suspension design. The axle shaft / CV joint angles would be too severe. "Lifting" will have to be accomplished by something like a sub-frame drop, etc, and in front that would mean dropping the entire powertrain. This is probably going to come down to kits for flares that include fender cutting, etc. to fit larger tires, and that's it. Perhaps someone will devise CV joints that can run at more extreme angles, too. I also expect development of electronic controls that override the KLs "automatic" rear wheel engagement, permitting direct driver control. The biggest consistent complaint from road testers has been that the KL is essentially a front wheel drive vehicle, and only engages the rear wheels when the fronts start to lose traction. There can, they say, be a significant delay in engagement, and that the engagement is harsh. Look for a switch or programming kit, or both, that permits the driver to manually engage those rear wheels.
The FDII patriot has an inch on the other patriots, and you can get a 2" lift from RRO for it. Its not Just that its an independent suspension, but that its designed to not allow for a spacer type lift. (at least that's the kind that you can get for a patriot from RRO...)
You can also get taller springs for the patriot vs the stock ones, this gives about an 1" for non FDII patriots, or about a half inch for FDII patriots over stock. I wonder if that is possible, to get a taller/stiffer spring in there. I
1 - 20 of 26 Posts
