Also are "Zone lift " any good ? I hear their shocks are similar to Fox buy not as pretty. Any truth to that ?
For a JK, you really can't go wrong with Metalcloak, Synergy, or Teraflex. There are a lot of companies that make good complete kits or components for the JK like AEV, OME, Rancho, Currie, Clayton, and JKS. If your looking at budget friendly lifts look into Rough Country. But take into consideration that some of the cheaper lifts will give you the height you want but will require additional parts to give you the ride and handling you want/need.
Avoid using Cam washers for caster correction and Trackbar frame side drop brackets.
For what you want, a couple choices would be:
Metalcloak Overland Sport kit with Control arm drop brackets and rear Axle side trackbar bracket. it's available in 2.5" or 3.5" but if you go 3.5", I would add a front high steer setup to it (raised trackbar and flipped drag link).
http://www.metalcloak.com/JK-Overland-Sport-Suspension-RockSport-Shocks-p/7147.htm
JKS has a nice complete kit with the control arm drop brackets, rear axle side trackbar bracket, and also raised front trackbar with high steer but it steps you into a 3.5"
http://jksmfg.com/i-20697409-jspec-...-wrangler-jk-4-door.html?ref=category:1044773
Rough country has a good 1.25" Body Lift that can be added if you want more height.
http://www.roughcountry.com/jeep-body-lift-kit-rc601.html
If you like the appearance of the factory flares but want more tire clearance or a taller look, you can get MOPAR high clearance flares. They allow a 35" tire on the factory suspension and a 37" tire on a 2" lift (I'm sure there are backspacing and bump stop requirements) They look like stock flares and use the same mounting, but are higher to provide more room for the tires and give a taller look.
http://www.quadratec.com/products/1...VNu_QHum4t9PmcEiFWCNrZ1pOhstTSYXGGBoCeNDw_wcB
If your wanting bare minimum in the lift for budget purposes a couple good options are...
Teraflex 2.5"
https://teraflex.com/shop_items/528ffa7fead962f416e72d47
Metalcloak 2.5" Touring kit
http://www.metalcloak.com/JK-Wrangler-Overland-Touring-Lift-Kit-p/7122.htm
Synergy Suspension 2" Stage 1 kit (you'll still see 2.5"-2.75" of lift)
http://www.synergymfg.com/Synergy-Jeep-JK-Stage-1-Suspension-System-2-Lift-p-16415.html
