Are you talking about the "No Trim", "Little Trim" & "Moderate Trim"?
If so, the "Trim" means trimming your wheel wells to fit the larger tires because if you don't your bigger tires will rub. So if, lets say, now that you have a 2" lift and you want to get a bigger size 265/70/16 (about 30.6" compared to stock 29.5"), you will have to "Little Trim" the front bumper because that will rub a bit when you flex or turn your wheels.
