If your profile is correct and you have the 2.5 you should already have 4.10 gears unless someone swapped in deeper gears at some point. Having a 2.5 TJ on 33's I can tell you it's pretty gutless. Your only options for a bolt in rear are the '87 to '95 YJ D35.
Why are you looking for another axle? The gears are too deep? There's only two steps deeper the stock 4.10's and that's 4.56's and 4.88's either are viable with 33's.
Sure you can get one from a TJ, but you'll be cutting off all the bracketry and welding on perches etc for the TJ, in which case you're 100% better off not getting a D35 at all and getting a 8.8 out of an Explorer.
You also cannot just swap the rear with a different axle / gear ratio because in the event you or someone else ever engages 4WD, bad **** will happen.
