I never had an operational 4.2 but generally an evap charcoal canister does the following.
The vent line to the canister from the tank should have zero suction resistance. Then there’s two lines to purge the canister- one is a limiting vacuum valve from the manifold that “opens” the purge line to the engine, and the other goes to either a choked manifold port or the air cleaner. Some applications have four connections and I can’t recall if the jeep 4.2 has 3 or four.
