1989 Wrangler 4.2L with complete top end from a 94 cherokee (MPI system & harness, sensors, etc)
Okay so I drove 250 miles through the AZ mountains no problem but as soon as I hit I-40 I got about 30 or so miles in and the engine suddenly started missing real bad then just cut out completely
I tried restarting it but it would just sputter and die instantly, or just crank with nothing
I let it sit there for about 20 or 30 minutes and it started up fine like nothing was wrong
it did this about 9 or 10 times so far, I made it to Albuquerque at least
I replaced the coil pack the first time it happened because I thought that was it, but it did it again about 30 miles later so I thought it was the TPS and unplugged that sensor, drove fine for another few miles then started doing it again, so I tried the MAP sensor, same thing
there are no check engine codes coming up, that is what frustrates me
