First thing I would check on the transmission would be to see if any codes have been thrown and note what they are.
Unfortunately on your year of TJ, the oil pressure gauge is no more then a fancy "idiot light". The oil pressure sending unit just sends a signal to the pcm that then moves the needle over to a set point. You may notice that the needle does not normally fluctuate at all once the engine is started. Even at idle the needle does not move discernably. There have been many instances of the sending unit failing and it appears the engine looses oil pressure. The only true way to check it is with a manual gauge hooked up to the oil gallery. If you find the oil pressure to be normal change out the sending unit. A down and dirty way is to poke a small hole in your oil filter and fire it up. Oil spraying out of the hole is a good sign, if not a little messy :surprise:. Be sure to replace the oil filter before using the Jeep if you try this.
