1 - 20 of 31 Posts
Product Information
Price $1
Average Price $234.03
Manufacturer rugged ridge
Recommended Yes: 29 / No: 2
bought this sye kit from just jeeps in toronto and is very easy to install, except for the fact you have to cut a bit of the shift fork to make it work other then that very good instructions...:cheers2:
Discussion Starter · #2 ·
Price $100
Pros very easy to install
Cons have to cut the shift fork to work
Recommended yes
Comments: was easy to install but had to cut the shift fork rod so it would not hit the new case other then that it is was a peice of cake to install. This was my first sye install and the instructions were very good..
Price $230
Pros Same as any other SYE I suppose. Great ride after the install.
Cons None.
Recommended yes
Comments: It looks like it has all the same components of any other SYE. They are pretty much all the same. The instructions were vague, but there are plenty of web sources like 4x4xplor.com to help with the details. It took four hours to install with a friend. Having a CV shaft in the rear is fantastic. I only have a 2-inch lift and would not have installed the SYE except for bending my stock output shaft. That said, I'm glad I installed the SYE the ride is smooth.
Price $150
Pros Great quality, most everyone who sells SYE's sell this product.
Cons Parts were missing
Recommended yes
Comments: Needed an extra snap ring, Omnix-ada sent it out no questions asked.
Gerat company.
Price $200
Pros much better angle on rear driveshaft. rugged ridge is a good company.
Cons had to get a bad (new) part in kit replaced, but did so with relative ease
Recommended yes
Comments: used the mega short kit, much better angle on rear driveshaft.
Price $400
Pros very easy to put in!
Cons had to cut shift fork bar. I was a little uneasy to go cutting on a part like this but all went well!
Recommended yes
Comments: The rugged ridge sye kit also came with a custom fit Adams driveshast . Seems to be very heavy duty compared to factory. All in all seems well worth the money.
Price $200
Pros Easy to install
Cons Needed a big set of snap ring pliers which I didn't know until I was already in to it
Recommended yes
Comments: Easy to install I have no problems yet
Price $150
Pros Easy install
Cons None
Recommended yes
Comments: Very easy to install but instruction included give vague pictures. Used a few writeups and a club member to install.
Price $240
Pros Good kit for the price
Cons Poor Instructions
Recommended yes
Comments: For the cost this seems to be a great kit so far. I was disappointed in the lack of instructions, Could have been more detailed and a few more "clearer" pictures. Definitely take the Transfer-case out I could not see trying to do this with it in.
Price $145
Cons Rear seal leaks had to buy a different seal
Recommended no
Comments: I was happy at first with the price and everything.
But with the rear seal leaking, the speedo pinion housing seems to stick out some I would have spent more money on a different kit with no problems.
1 - 20 of 31 Posts
