I wasnt going to do a build thread but I have hundreds of pictures that I figured I would at least post up. Its Jeep porn as my wife calls it. :laugh: A little about me. I am a bonified 4x4 nut. I am on my 3rd Wrangler, second Rubicon, and Solid Axle swapped a newer Bronco with E Lockers, trying to make if feel like a Jeep. Ended up selling it and buying another Rubicon. Love working on my vehicles. And I love my tools tools tools. I have a 180 Mig Welder, large assortment of tools, 4 Jack stands, air tools air tools air tools! My family and I are military, I love this forum, and of course love Jeeps.
Here is where I am currently:
315/75R16 Maxxis Bighorn MT on Moabs with Spidertrax spacers
BDS {3" Springs, Rear sway bar Links)
Doetsch Tech Shocks {DT3000)
ROKMEN {JJ Adj. Upper/Lower CA, Gas tank Lift/skid)
JKS {Track Bars, CV Bracket, Quicker Discos, MML, 1"BL)
Procomp 2000 Steering Stab
Coast HD 1350 Double Cardan
Novak NP241OR 4WD Cable
UCF TumTuk
ToysbyTroy Winch STINGER
Rampage Recovery Rear/Tire Carrier
Stealth Alpine Audio System/500wRMS Kicker L5 Sub
Burned on Clayton Rear outboard shock mounts.
Rear back up lights installed into the rear bumper recesses
Here is the short term:
Front Upper and Lower Control arms (rears are done for the CV and tumtuk)
JKS front track bar
Bump stop correction
And for the Long term:
4.88 or 5.13 gears, overhaul kits, installed by me
Outter axle seals since Jeeps screwed that up with plastic dust covers and inner axle seals (when needed, good for now)
Rockers Guards (sell rubicon rockers)
Corners and Front Fenders
Winch
Done
Currently Stance : By the numbers ---- Mod ---- Description
CLEARANCE
17" ---- Tummy Tuck ---- UCF ground clearance
17" ---- Gas Tank Skid ---- ROKMEN ground clearance
11" ---- Axle Clearance Front ---- From the lowest point (diff)
10.5 ---- Axle Clearance Rear ---- From the lowest point (diff)
73" ---- Overall vehicle height ---- @ the top of the windshield
34.5" ---- Height Tires ---- Maxxis Bighorn MT
12.5" ---- Width Tires ---- Maxxis Bighorn MT
3.75" ---- Backspacing ---- Spidertrax 1.25" Hub Centric on Moab 16x8
5" ---- Top Tire to Fender Clearance ---- Stock (Metal Cloak, TNT, other)
3" ---- Lift ---- BDS
1" ---- Motor Mount Lift/Body Lift ---- JKS
SHOCKS (Doetsch Tech DT3000)
4" ---- Front shock piston showing ---- Bump stop limited
6" ---- Front piston droop ---- Shock limited
10" ---- Front Travel ---- Untested
2.25" ---- Rear shock piston showing ---- Bump stop limited
7.75" ---- Rear shock piston droop ---- Shock limited
10" ---- Rear Travel ---- Untested
? ---- Ramp Score ---- Untested
94" ---- Wheelbase ---- Stock, Rokmen Upper Lower Arms
OTHER
? ---- Operating Weight ---- Bumpers, skids, vehicle, full tank, winch, driver
12.4 ---- Hwy/cty MPG ---- on 33's with exact speedo, 35's untested
73,xxx ---- Mileage ---- Feb 2012
13,000 ---- Price Paid ---- Feb 2011
Current Stance: By the Pictures
UCF TumTuk
JKS front track bar
Winch
Done
CLEARANCE
OTHER
