Solved: Rough idle, misfiring/buckling >1200 RPM, PCM readings go nuts, NO CEL's
Solved: Need help with tracking down phantom like symptoms that are rendering our '00 TJ 2.5L undriveable.
Turns out I had numerous problems:
- Stuck lifters #3 cyl, convexed face w/ metal edges flared outwards. Replaced
- Bad Camshaft, lifterswore grooved into lobes. Replaced
- Melted wiring harness around valve cover causing numerous sensor signal noises.
Replaced 1/2 of wires between ECU & connectors, all wires insulated w/ heat shrink tubing
- Other parts replaced: Coil, CPS, Evap Purge Valve and Pump, Original CKP reinstalled.
Runs well now. May need new Cat to complete readiness to pass SMOG test.
Only remaining issue: slightly rough idle. At low RPM's (in park or driving), when applying slight throttle, the increases as expected, then drops back down withing a second. TPS monitor shows the slight increase despite RPM drop. No apparent "bald" spots. No CEL's, pending or otherwise. IAC appears normal in response to RPM changes and has no RPM surges or stall conditions. AT seems to lurch at certain RPMs, as if it's changing between gears and reverts back to prior state.
Oddly, when the Evap Valve was set to Open by a local shop, the idle seemed to smooth out. I don't recall exactly, but I believe the RPM drop improved too. Last night, I noticed variations in the vacuum readings. Don't know if this is a fluke/delayed response to my OBD scanner and Torque Pro app.
Not sure how to figure this one without paying to have it scoped. May have to pull TB and clean it thoroughly, not just spray more cleaner in it.
Suggestions would be appreciated!
----------- Original Post ------------
NO CEL's thrown. OBD-II readings indicate different problems on different tests/days. ~98k miles on engine.
Background:
- Several ignition components and sensors were replaced including the fuel injectors (Bosh upgrade) and a top end rebuild.
- Numerous other parts and connectors have been checked and/or cleaned.
- Top end rebuilt. Cyl walls still have some crosshatching and no scorch marks or signs of unusual wear.
- CAT seemed OK based upon rear side reading ~100 degrees hotter than front, no rattles, sounds etc.
- Distributor coil resistance in spec, Distributor shaft has minimal play ~1.5-2.5mm.
- Timing chain seems ok - minimal crank rotation at damper bolt. No noises around cover plate.
- Replaced bad 2nd IAT, then IAT spiked indicating wiring problem, went away next day.
- No RPM surging.
- Fuel rail pressure (not running) in spec. No further testing due to rail leaks at the time.
- PCM tested under varying conditions, loads AND when heated with a heat gun. Program updated. NO problems found.
- PCM Black Connector: DID find corrosion on right side roughly, say near pins 1-3, 12-13, 22-24!! Cleaned w/ electrical contact cleaner.
- PCM reset after each new component replaced or as indicated.
- Drained oil looks clean (NO metal observed visually or w/ magnet).
- No loud/odd sounds under engine oil pan area.
- Battery fully charged, Alt charges properly, all ground straps look good.
- No signs of wiring harness or connector problems.
- Evap ECS cleaned, some hoses replaced, hoses secured w/ clamps or twisted wire.
- Generally cold starts fine with very slight misfire until....
Current Observations:
-Upon cold start, the PCM OBD-II readings generally look good at idle. Warm restarts can be a different issue...
Once it warms up a bit (closed loop), increasing the rpm's above 1200-1300 usually causes misfiring, knocking and buckling. On a very few occasions, I'm able to get it up to around 3k rpm but may have to feather the throttle to return to idle w/o stalling.In both situations, upon returning to idle long enough, and throttle feathering if needed, the OBD-II reading often settle down. Other times, I have to restart the engine once or twice.
-Overall, the OBD-II sensors appear to be working properly but show the PCM is trying to compensate for odd inputs.
-The timing usually advances above spec and often the neg ST and/or LT fuel trims and O2 sensors would indicate a high fuel/air mixture. Other times, the high O2 readings indicate the opposite. Given the slow OBD-II sampling rate, I can't extrapolate any deeper.
Suspicions/Questions:
- A wiring harness short somewhere is at the top of my list. Could be at either end connectors, in between, or somewhere else in the ignition/fuel delivery/sensor circuit. On the other hand, I don't know if it's heat, vibration, rpm or load related.
- The observed and cleaned PCM corrosion (not too bad), still haunts me. I'm leary of trying to open up the black connector given how brittle many plastic parts have become.
- Could a weak PCM harness sensor ground connection (A4) or perhaps any/several of the other close-proximity sensor connector pins?
SO, ADVICE ANYONE?
Has anyone experienced this type of issue or related problem(s) and have any solid advice?
I'd like to avoid ripping open all the harnesses to inspect every inch only to re-wrap everything with a bunch of cloth tape rolls.
I'm not sure how to carefully clean the inside of the black PCM harness connector pin holes near the corrosion area noted above.
So, I was thinking of checking continuity and resistance by inserting test pin probes into several of the PCM connector holes and at the component end connectors. Would that suffice given the possibility of heat, vibration and/or voltage (sensor reading) spikes?
Thanks!!
Background:
- No RPM surging.
SO, ADVICE ANYONE?
Thanks!!
