1 - 16 of 16 Posts
Product Information
Price $179
Rating 4
Average Price $157.73
Manufacturer Rough Country
Recommended Yes: 15 / No: 0
Company website http://www.roughcountry.com/jeep_xtras_xflex-control-arms.html
Rough Country X-Flex Adjustable Control Arms Lower
Kit Contents:
Tubular adjustable control arms with X-Flex Joints, polyurethane bushings, sleeves, and grease fittings.
Description:
Fully adjustable control arms replace your factory stamped sheet metal OE arms and allow for better articulation and more control off road but does not sacrifice on road handling. They are fully greasable, and come with highly durable polyurethane bushings. A must have for a trail ready Jeep.
Discussion Starter · #2 ·
Price $179
Rating 5
Pros Solid, well built, attention to detail, EXCELLENT price and great cost/benefit ratio. Greasable and adjustable!
Cons None?
Recommended yes
Comments: Owned a set of the adjustable lowers for just over 1 month now. I had them installed as I had no time, but my friend (also my mechanic) said that they went in easy peesy. Very easy to adjust, solid and well built.
On road they increased the tracking of the steering greatly, solid feel, excellent cornering and honestly I believe that the Jeep handles 25-30% better now. Solid feel when hitting bumps at speed, and tracking is superb.
I highly recomend a look at these if you are in the market for some adjustable LCA's or UCA's. A must for a lifted rig IMHO to get castor correct and to properly set up suspension and assignment.
:thumbsup::thumbsup:
2 thumbs way up!
Price $179
Rating 5
Pros Excellent Product, flexes very well and looks to be very much over built.
Cons Non!
Recommended yes
Comments: I love this product, good product for the price that it sells at...I recommend it to anyone looking for a very good and priced well short arm replacement.
Price $150
Pros Fixed some Alignment problems! Much Beefier!
Cons None
Recommended yes
Comments: After a 6" lift I had terrible alignment issues! The Lower Adj Control arms helped out alot!
Price $150
Pros strong ... x flex end is nice
Cons rought country
Recommended yes
Comments: easy to in stall beefy and cheao
Price $179.99
Pros Affordable, flex joint, adjustable, rebuild-able, 90 degree grease zerks, 1.5 inch .120 DOM
Cons Would be nice if they included some hardware, new bolts, etc. Instructions are garbage, just throw them away.
Recommended yes
Comments: I needed to replace my stock stamped steel control arms, they were badly bent and starting to affect camber, etc.
Sure, we all would love to have Currie this and Rokmen that, but in all honesty, for the money, I would rather put that into an SYE than have high end lower control arms that serve the same purpose of these. Not to talk down Currie or Rokmen of course, they are top of the line. We just can't all afford to buy everything from them and still put gas in the tank.
These are great control arms, tough, and do what I need them to do for the kind of wheeling I do. That is why I recommend them.
Price $180
Pros Why pay $50 more for more of same
Cons Not double johnny 'top of line' arms.
Recommended yes
Comments: replaced my Tuff Country arms. I've not had them long enough to comment. Johnny joint end come pre-assembled which is very nice.
Price $190
Pros Adjustable, heim joints, excellent flex
Cons bushings squeak if they're not greased every 1000mi or so.
Recommended yes
Comments: I am very satisfied with these control arms. They do everything and more than I ask of them for a short lift.
Price $0.01
Pros free
Cons no ID
Recommended yes
Comments: the were installed before I got the Cherokee, I discovered them while R&R Ball-joints.
· Banned
Price $100
Pros Adjustable, greaseable, strong. Fits WJ's with a spacer.
Cons Really tough to reach grease nipple on WJ. Squeaky polyurethane.
Recommended yes
Comments: Rough Country adjustable lower and upper front control arms for XJ also fit WJ if you use spacers on the lowers.
Requires two fender washers per side at frame end & six fender washers per side on axle end.
Price $179.95
Rating 5
Pros Super beefy, easy install, easy to adjust, rides like a cadillac
Cons none I know of yet
Recommended yes
Comments: Packaging was smashed a little, opened up, not worried at all, arms are REALLY beefy! Nice and heavy. Bought these to fix my caster angles and WHAT A DIFFERENCE! Rides nice and smooth now...
Flexes real nice over rocks, logs, stumps...
Love.
G
Price $180
Rating 5
Pros less money then others and work great
Cons nothing yet
Recommended yes
Comments: 2.5 years, so far they have been great.
Price $150
Rating 5
Pros I have had them over 3 years and no problems
Cons none
Recommended yes
Comments: I have had them just over three years with no problems and they work great
Price $179.95
Rating 4
Pros Great quality
Flexible joints
Greasable
Good Ride
Cons N/A
Recommended yes
Comments: Not difficult to install, provide correct length control arms with lift. I would recommend the control arm drops brackets with these in order to provide the correct angle.
1 - 16 of 16 Posts
