Plan man has good info. Whatever you do, get hub centric.
RC 1.5 5x5 (model 1091 for JKs) spacers ARE hub centric.Plan man has good info. Whatever you do, get hub centric.
If you need a spacer wider than 1.5" the width of the tire you are planning to run requires at least an 8" wheel, while stock is 7.5".Spidertrax because they sell 1.75" spacers. If you have stock jeep wheels they have a 6.25" back space. Target is typically listed as 3.75" to 4.5". If you go with 1.75" spacers you'll end up with 4.5" of backspace.
Spacers are not only used with stock wheels. I bought them to run 40s on Walker Evans beadlock wheels that had 4.5" backspacing so that I could turn my jeep without rubbing the paint off the frame.davison0976 said:If you need a spacer wider than 1.5" the width of the tire you are planning to run requires at least an 8" wheel, while stock is 7.5".
What part of my post are you not agreeing with?If you need a spacer wider than 1.5" the width of the tire you are planning to run requires at least an 8" wheel, while stock is 7.5".
Ok. I never said they weren't.RC 1.5 5x5 (model 1091 for JKs) spacers ARE hub centric.
Planman, I was sort of thinking the same thing. I want to commend you on all of your explanations & additional details in this thread. You even post scientific proof and the "skeptics" are still not convinced. I might have access to a reputable testing facility if it comes down to it. But would hate to call in a favor just on account of wheel spacers...You have so few posts here.
Why not tell us about your background, who you work for, your experience with jeeps, etc.?
Your initial post in this thread as glowing praise for RC and mocking Spidertrax, followed by some engineering observations, etc., begs the question.
