Product Information
Extreme Flex without the Extreme Price
Front: High flex coil springs, lower high clearance arms with X-Flex Joints, upper control arms with X-Flex Joints, control arm mounting brackets, adjustable track bar with drop bracket, drop pitman arm, sway-bar disconnects with parking bracket, and stainless steel brakelines.
Rear: High flex coil springs, lower high clearance arms with X-Flex Joints, upper control arms with X-Flex Joints, adjustable track bar, extended sway bar links, stainless steel brakeline, and bumpstop extensions.
Shocks: Kit includes (4) High Performance 2.2 series shocks.
Notes:
• Does NOT fit Unlimited models
• Slip Yoke Eliminator with CV Driveshaft is
recommended to avoid driveline vibration.
• Rubicon models do not need SYE kit or
CV Driveshaft.
• Exhaust will have to be cut and rerouted to make
sure it is away from the moving components.
Benefits:
• Flex joints designed by Rough Country.
• Includes our 2.2 High Performance Shocks.
• Features high clearance lower control arm design.
• Extreme travel long arms keep optimum alignment
and give optimum articulation.
• Unbeatable value and best prices in the market!
• Upgradeable with our Jeep X-tras. - Click Here -
Specs:
• Part #: Perf663
• Install Time: 8 - 9 hours
• Wheel Backspacing: 4.5"
• Recommended Tire Size: 33x12.50
Price | $1299.95 |
Rating | 5 |
Average Price | $1208.75 |
Manufacturer | Rough Country |
Recommended | Yes: 16 / No: 0 |
Company website | http://www.roughcountry.com/index.html |
Notes:
CV Driveshaft.
Benefits:
Specs:
• Part #: Perf663
