1 - 3 of 3 Posts
I am currently running a 2" OME suspension lift on my 2009 wk, and I'm looking to get it a bit taller and maybe be able to fit a bit bigger tires. I was looking at the rough country - 664 - 2 inch lift (http://www.amazon.com/Rough-Country...F8&qid=1459540272&sr=8-1&keywords=wk+lift+kit) I just wanted to hear some opinions on whether or not I could run the two together and if it would make much of a ground clearance/height difference. Thanks for any help!
Unless you want to get the OME 3" kit, your only option is a 4 1/2" kit.
You can't run a RC lift with an OME one. Though you can modify the OME kit, there should be a bunch of threads about it
You could run the rear spacer with the rear OME springs and swap out your front shocks for adjustable 5100s, but you'll need more than that to accompany the added lift- new UCAs, rear trackbar, etc.
Like mentioned, if you are looking for 4" or more of lift- go with a 4" superlift
1 - 3 of 3 Posts
