1 - 20 of 1154 Posts
I have been wanting to start a build thread on here for a while now. I am starting my thread somewhat late into my build but I'll catch everyone up. Alright so here it goes. This is my second car. I had a 2005 Chevy Avalanche 2WD that was a graduation present from my parents for graduating at 16. I wanted a 4x4 so I talked to my parents and for too many reasons to mention they let me sale it without them holding it against me that I had only had the avalanche for 9 months before selling it. I found someone to pay good money for it and bought this 2001 Cherokee Sport. Luckily for me the Cherokee I ended up getting, already had a 3" BDS Suspension lift kit, a roof rack, a pair of Hellas and Rubicon/Moab 16 rims, other than that fully stock
The third day I had her.
How she sits now:
what else hve u done to it
2/5/2010: First Upgrade - Putting a new sound system in it. I am a person who loves music and could not live with the crappy stock sound system so the second day i had my cherokee i went on a sound system shopping spree. Bought a Kenwood Head Unit, Alpine speakers for the front/rear and a Rockford 10" sub and amp.
3/5/2010: My next add-on was a CB-Radio. I decided to mount it in the head board between the sun visors. Mounting it there posed a problem because I didn't want to accidently put a hole in my roof but at the same time the screws that I was using didn't hold it in the head liner at all, So I decided to use toggle bolts to hold it in and so far they have held up to the constant shaking when off roading. For my antenna I used a normal 6 foot whip from radioshack that i cut down to about 4 feet that is mounted to my roof rack.
4/15/2010: I had trouble with my alternator when I went out wheelin one day, so started looking into some kind of skid plate or splash guard to try to keep the mud and water out. I was rolling around in a junk yard one day looking for one of the stock splash guards for my cherokee when I found a front skid plate, for $15 I didn't think it was so bad. after a little paint job it looked like new.
Discussion Starter · #11 ·
7/13/2010: Who ever owned the Jeep before me added a 3" front 2.5" rear lift kit. but sense I put the bigger tires on my Jeep that 2.5" of lift in the rear was not working out so I installed a 1.5" Rubicon Express block in the rear replacing the half inch block that was already there, lifting the rear an inch giving me a total of 3.5" in the rear. I also added a 3/4" Rubicon Express coil spring spacer in the front to kind of balance it out giving me a total of 3.75" in the front. Not sure if you can really tell that the block is installed in these pics or any I seem to take but I can tell in person. The reason for the mudd is I wanted to see if the block was stopping the reason I bought it in the first place and that was tearing off my fender flares in the rear. Unfortunately they didn't help to much, they gave me a little more room to flex but didn't fix the problem but what the hell it looks better now and I had fun getting her dirty!!!
I like that flashlight mount. nice build so far.
Discussion Starter · #18 ·
11/9/2010: Front inner fender work. Did the cut-n-fold to the inner fender. I was reading a forum and saw that some one used a pool noodle to block off water and mud from getting to the door then into the cab. So I did it. Just used a normal pool noodle, cut it in half, shaved it down a little, stuffed in the fender then used Great Stuff insulation foam to fill in the gaps and hold it in. After that I undercoated them with Rust-Oleum Professional rubberized undercoating.
Discussion Starter · #19 ·
11/12/2010: Finished my homemade sway bar disconnects. I would have bought them and will most likely end up buying better ones, but i didn't not want to waste the money on sway bar links that stop at 3 inches of lift when I am planning to go bigger. Just bought some hitch pins from Lowes, had to use a pitman arm puller to get the studs out but after that it went pretty easy. On the top just drilled a hole through a stuck a hitch pin in and it worked fine.
Discussion Starter · #20 ·
11/20/2010: Made a Hi-Lift rack mount today. I think it was pretty innovative. I took the old U-bolts from when I added a the rear block. Bought a piece of 3/16"x2"x3' steel strip from Lowes, cut it down to the measured lengths, drilled a half inch holes. Started to paint them when I ran out of black paint (thats why two of the plates are white). Then put them on.
