1983 CJ7 258 T4 all stock. 1984 CJ7 258 Automatic Howell Fuel Injected
Just a brief backstory, apologies if it's too long... I have an all original 83 cj7 I bought after high school in 1998 that I still own, maintain, and drive regularly in the summer. I have purchased an non running 84 cj7 within the last year as a gift for my Dad and am in the process of restoration and looking for some expert advice from this awesome forum that has helped so much over the years. I was told the 258 engine was rebuilt and was in good running condition with the Howell fuel injection when it was parked 7 years ago, but when I started changing fluids I found some issues. There was coolant in the oil first thing, so I have removed the head, had it machined and magnafluxed and reinstalled with a new felpro head gasket and ARP head bolts hoping that it was just a bad gasket when parked years ago. Also removed the oil pan to clean out the sludge, replaced the gasket and replaced the rear main seal. All other fluids so far have looked ok. The 20g gas tank was near full when parked so all the old fuel was removed, poly tank cleaned, and new metal supply and return lines installed. Haven't installed the tank yet. Recently added fresh oil and spark plugs, turned the engine over by hand several times with some marvel mystery oil on top of the pistons and attempted it's first start just to see if the mess of wiring would work as is and to diagnose any other issues or to try and determine if the motor was shot. I turned the key on several times so the electric fuel pump was primed and made sure the gas was clean before hooking it to the throttle body. I was pretty surprised that it actually fired up on the first try. Only ran a few seconds but it started every time after that and eventually would run for a few minutes, but the idle was too high and eventually it would just die but I was able to get the engine warm and am satisfied for now and can address the running issues later, I don't know how to diagnose this Howell system yet. SO I'm in the process of removing the sheet metal to turn over to a body and paint guy that is going to work on the typical rust issues and paint it as a side job over the next probably several months while I work on the rest.
Well when I removed the windshield frame and took off the cowl seal it looked pretty bad. Do you think this frame is fixable or trash? I have read that the aftermarket ones have issues and finding a rust free original is getting pretty hard. Any advice is appreciated and feel free to chime in on any other topics. Thanks!
