1 - 3 of 3 Posts
I installed a 4in currie lift. w/ double adjustable upper control arms. Installed the rear track bar relocter bracket. and I cant get my stock rear track bar to fit. At first i realized my axle was to far foward. So i adjusted my lower control arm about 1.5in to move my axle back. Then adjusted my uppers so my pinon angle is roughly 9deg. Its a lot closer but it seems like my track bar needs to rotate. I was told that i can use my stock track bar. Im a little confused on what to do and any help would be appreciated.
· Wizard of Brakes
Whoever told you that you could use the stock track bar lead you on a merry trip down the garden path. Yes you can, but now you see why you shouldn't. You "should" be running an adjustable with the tilted bracket.
1 - 3 of 3 Posts
