If you are going single shear like with a spindle for a hinge your best bet is to look for one that has the hub with it instead of cutting a hub. The hub is usually cast and won't weld up as good. And the better units have a sleeve you weld into the bumper so you don't have to weld on the spindle and screw up the temper. These usually have set screws to hold the spindle in the tube.I hear ya guys, did a bit of research and that bike thing wouldn't work.
So what your saying is something like this; https://www.princessauto.com/en/detail/1-250-lb-high-speed-trailer-stub-axle/A-p2080000e
And cut the centre flange around it off?
I'd order the AtoZ spindle its a good price, $55 however after shipping to Canada the thing cost me $140 plus exchange... which is a bit too steep. And I'd prob get dinged with duties on top of that.
You have a link to one that has the hub with it? Isn't what I linked above what you are referring to?If you are going single shear like with a spindle for a hinge your best bet is to look for one that has the hub with it instead of cutting a hub. The hub is usually cast and won't weld up as good. And the better units have a sleeve you weld into the bumper so you don't have to weld on the spindle and screw up the temper. These usually have set screws to hold the spindle in the tube.I hear ya guys, did a bit of research and that bike thing wouldn't work.
So what your saying is something like this; http://www.princessauto.com/en/detail/1-250-lb-high-speed-trailer-stub-axle/A-p2080000e
As far as that single shear pivot point holding all the weight of a heavy tire and wheel while bouncing down the road I suggest you build a "rest" for the latch end to sit on. I've built a couple of them and used pieces of cheap urethane cutting board for the rest. The rest will fit between the bumper and swing and be a slight interference fit.
Personally I'd go with a double shear pivot. Much harder to snap off.
Weld an upright to the bumper and weld this to the upright.
Heavy Duty Relentless Double Shear Style Pivot ? Relentless Off-Road Fabrication
I use two 1" pin double shear hinges on mine, but I also have my tailegate hanging on the swing and a 125 lb toolbox mounted inside the tailgate. 10 years now and no issues whatsoever.
You mean this?You have a link to one that has the hub with it? Isn't what I linked above what you are referring to?
Are you refering to the spindle that's not welded in but the sleeve in the pic above?.... The sleeve welds in then the spindle presses in no one will be able to pull that out without super man brute strength. The idea behind that setup is welding the spindle to the bumper makes it brittle so has a possibility to crack and break off.Now that looks like a nice unit but why the price tag as well.
I'm almost just considering using the pin and sleeve that came with the bumper. drill in a zero fitting in the side of the sleeve and call it good.
I'm just unsure how the whole carrier stays down and what prevents someone from simply picking it up of the hinge..
. I think he was referring to the kit unit he already had, just a post with a piece of tubing over it.Are you refering to the spindle that's not welded in but the sleeve in the pic above?.... The sleeve welds in then the spindle presses in no one will be able to pull that out without super man brute strength. The idea behind that setup is welding the spindle to the bumper makes it brittle so has a possibility to crack and break off.
dwilliams35 is right. This is what I was referring to;Are you refering to the spindle that's not welded in but the sleeve in the pic above?.... The sleeve welds in then the spindle presses in no one will be able to pull that out without super man brute strength. The idea behind that setup is welding the spindle to the bumper makes it brittle so has a possibility to crack and break off.
It's just a bolt.... drill a hole, stick it through, tack down the head.For the spare tire mount - what do you guys do, buy new wheel studs and weld them to the plate or what?
It seems the studs on the stock carrier are spot welded on..
Destaco is more money than the others but well worth while.Well I can't believe it but the bumper is basically nearly done. The carrier came tougher - found a local mechanist and he helped me out with the spindle/sleeve idea and it works beautifully. I've welded everything together and only a couple of items left to figure out.
1) The carrier once on the Jeep seems to bounce a bit. I haven't figured out a latch idea (thats my second point). but I'm wondering what do you guys recommend to prevent this? The end where the latch would fall sits pretty much on the top of the rear bumper.. It seems the bounce is at the upper part of the A-frame.
2) Any recommendations for a latch? I see a lot of guys use these Destaco latches, are they good and worth the money?
3) Paint, but thats a easy one!
I did the destaco route; its got an actual tension to it that'll lock down the rattling pretty well. I doubt you're going to get the same level of tension with a bolt/t-handle without a cheater pipe or something, and you can open the destaco in about a second.Well I know I have to adjust the rear rubber snuggers I'm sure it's going to help. And the latch end I might just do the whole bolt with a T handle on it as it seems to be the best and most fail safe.
However the bumper shouldn't bounce that much lol or am I missing something here?
Ya the destaco latch looks nice but I also read a few times where it actually let loose.I did the destaco route; its got an actual tension to it that'll lock down the rattling pretty well. I doubt you're going to get the same level of tension with a bolt/t-handle without a cheater pipe or something, and you can open the destaco in about a second.Well I know I have to adjust the rear rubber snuggers I'm sure it's going to help. And the latch end I might just do the whole bolt with a T handle on it as it seems to be the best and most fail safe.
They do make the destacos with safety latches....Ya the destaco latch looks nice but I also read a few times where it actually let loose.
I drilled and tapped a couple of holes today in the arms and added a couple of rubber feet I had laying around to get the tire snug on the arm. Next step will be to get the whole a-frame to be snug against the tailgate..
