Control arm bushings way too stiff. Rear swaybar links a PITA. Not a fan of the front jounce bumper (bump stop) landing pad. Front swaybar disconnect washers kept flying away in the wind.
Recommended
yes
Comments: Fairly complete. Had pretty much everything needed for a lift. Front panhard is adjustable so tire rub can be mitigated without messing with steering stops. Control arm bushings way too stiff. Rear swaybar links a PITA--the stock flag nut is not reusable and trying to use a non-flag nut in that tight space was frustration defined. Not a fan of the front jounce bumper (bump stop) landing pad--used a set of extended jounce bumpers instead. Front swaybar disconnect washers kept flying away in the wind. Otherwise a good product.
Lifted 2.25" in front, 1.75" in back, exactly as advertised.
Cons
None
Recommended
yes
Comments: Springs and adjustable shocks bundle. Lifted exactly as advertised. Adjustable shocks make a noticeable difference in firmness of ride. Nice to be able to adjust for load, towing, road type, etc. Rancho had $100 rebate off the price
727.5K members
