Temporarily opened for suggestions..
For a video, go here: https://www.jeepforum.com/forum/f8/quick-gauge-test-4390781/#post40900235
CJ Speedometer Gauge Quick Test
By: John Strenk
OK, You know what your doing. You don't need a long explanation. Just a test light. Maybe a DVM.
One Warning. A poor broken ground connection or hooking up the plugs incorrectly can quickly burn up the gauges or sensors. Don't make matters worse. Double check your connections before turning your ignition key to 'ON'
Add a ground wire from the dash to the (-) negative terminal of the battery to be sure.
Step 1. Start Here
Turn key to ON. Attach your test light clip lead to a good ground.
You may want to disconnect your Ignition coil. These have been known to burn up if the key is 'ON' but the engine is not running.
By: John Strenk
Step 1. Start Here
