As Jeff would say, today was a good day in the receiving department.
I ended up buying the Autometer gauges from Nick(Janesy86) and they came in today. The gauges look sweet, and I think they'll look even better hooked up and running in my rig. I need to do a little research and see what I need to do to get everything to run properly with my setup but I'm pretty excited.
I also went and farted around at the junk yard today. I picked up another Magnum intake that I plan to mess around with. I'm thinking of doing a mild port/polish, cutting down the runners and then either building or buying a set of volume reducing plates.
I was able to fortunately find the intake that I needed just sitting in the passenger seat of a truck. That really saved me the time of having to remove one from a vehicle. All I needed to do was remove the throttle body, fuel rail and injectors and I walked out paying $21 after tax.
Once I brought it home I planned to leave it in the garage for now, but it smelled like fuel from removing the injectors so I had to give it a quick bath real quick. I removed all of the old hoses and removed the belly pan so I could get everything pressure washed
I then let it soak in some oven cleaner for a minute
And finally it was clean enough to store in the garage without giving you a headache. I plan to get way more in depth with cleaning it later on.
