1 - 20 of 72 Posts
Build thread to track progress and seek advice on methods and techniques for building my 1994 YJ.
I bought this YJ with a previously installed 5.3 LM7 V8, SM465 transmission and NP231 with SYE.
It also had a 8.8 rear and original D30 front, 4.10, cable lock actuator and open diffs.
Not quite sure on the end state goal; it will change regularly as I wheel it and as my budget allows, but I'd like a very capable rockcrawler Jeep to be used at Gulches, Windrock, River Rock, Uwharrie and other parks. The intent is to trailer mostly but I also will daily drive it occasionally.
Let's get started
Purchase day pics-
Wheel Tire Car Vehicle Automotive parking light
Discussion Starter · #5 · (Edited)
Next I had to get rid of that tube bumper and install a winch. Quick short-term solution was a Harbor Freight universal plate on the frame and the Warn XD9000i off of my trailer. The winch looks like it spent time on the bottom of the ocean but it still pulls reliably and relatively fast.
Tire Wheel Automotive parking light Vehicle Motor vehicle
My buddies sprung a trip on me last minute to Kairos Wilderness Resort, Glen Lyn, Virginia; so I loaded up the YJ and took it places it shouldn't have been.
It did very well to keep up with open diffs, but eventually I got happy with the rev limiter and broke the passenger side axle u-joint.
Automotive parking light Tire Wheel Car Vehicle
Tire Car Wheel Vehicle Plant
Plant Tire Wheel Vehicle Plant community
Wheel Tire Vehicle Car Automotive tire
Discussion Starter · #7 · (Edited)
During the trip I also dented both rockers and driver's fender due to expert driving and will power. The jeep was given a duct tape bikini top and earned the pink shackle for being the last to winch out. It's in need of a cooler.
Wheel Tire Land vehicle Vehicle Automotive parking light
Wheel Tire Automotive parking light Vehicle Plant
Car Vehicle Motor vehicle Steering part Steering wheel
Discussion Starter · #8 ·
I traded a friend for a replacement short side axle shaft with a new u-joint and found everything else in the front end to be well serviced and in good condition. The inner axle seal and Posi-Lok cable collar took a little extra work to align, but now it's working perfect.
Tire Wheel Automotive tire Motor vehicle Tread
Sports equipment Auto part Fashion accessory Personal protective equipment Carmine
Discussion Starter · #9 ·
I found a tire and wheel combo on FB marketplace that I liked, so I made them work with bolt pattern adapters from 4.5 to 5.5.
315/70R17 Cooper Discoverer AT3
17x8 Method bronze wheels
Tire Automotive parking light Wheel Vehicle Grille
Discussion Starter · #10 ·
Next find on FB Marketplace was new unused Corbeau Sport seats. These are Jeep CJ/YJ replacement seats with recline. Bolt right in, but they do sit high and add width so limited center console options. I also had to bend the ridiculously long SM465 shifter in order to get clearance for all gears.
Vehicle Car Steering part Motor vehicle Automotive design
Car Vehicle Motor vehicle Hood Steering part
Discussion Starter · #12 ·
I fixed some exhaust hangers, changed all fluids and put a bunch of miles on the YJ driving it to work and everywhere enjoying the summer in an open jeep. Took it to River Rock ORV, Milledgeville, GA for a hot day and it did great for a short wheelbase YJ on AT tires. No action pics taken.
Wheel Tire Plant Automotive parking light Vehicle
Tire Wheel Land vehicle Vehicle Automotive tire
Discussion Starter · #14 · (Edited)
While in FL I picked up a set of 37x12.50R15 Super Swamper TRXUS tires. I got home a mounted them on 15x8 steel D windows and tried them on the YJ. No way were they going to clear, so I used some rear flares meant for my TJ and cut out the rear wheelwell openings till they fit satisfactory.
Tire Plant Car Wheel Vehicle
Wheel Tire Automotive parking light Car Vehicle
Automotive lighting Wheel Automotive tail & brake light Vehicle Automotive tire
Tire Wheel Vehicle Automotive tire Tread
The rear axle is now needs to move rearward to properly align with the wheelwell opening, but I'll get to that once I replace the gas tank.
Tire Wheel Automotive tire Vehicle Motor vehicle
Discussion Starter · #15 · (Edited)
Of course the front fenders needed help for tire clearance and to remove the dents and memorys of driving into trees in VA.
I found some new Metalcloak fenders for a CJ7 on marketplace and thought I’d give them a try. They are a few inches short, but otherwise bolt up. Ordered flares from Metalcloak.
Wheel Tire Vehicle Automotive tire Tread
Tire Automotive parking light Wheel Vehicle Motor vehicle
Tire Wheel Plant Car Vehicle
Discussion Starter · #17 · (Edited)
Loaded up the YJ and went to Sheriff's Jeepfest in Jasper, GA. It was a great event with a good show, lots of vendors and moderate trails and obstacle course. They increased in difficulty as the rain came, but I was really impressed with the Swampers.
Wheel Tire Land vehicle Vehicle Cloud
Tire Wheel Plant Vehicle Car
Cloud Sky Car Vehicle Tire
Wheel Tire Vehicle Car Sky
Discussion Starter · #20 ·
When I pulled it out of the trailer I noticed a bad oil leak. Somewhere on the back of the motor, so I replaced the cam position sensor and o-ring but it kept coming. I have no idea on the motors mileage, but I do know I’ve had it on the rev limiter many times, so I assumed it was the rear main seal. Pulled the trans and replaced both main seals on the back of the block. Also fixed the trans mount while putting it back together.
Gas Electricity Engineering Machine Tunnel
Tire Wheel Automotive tire Hood Vehicle
1 - 20 of 72 Posts
